Thread: Racetronix fuel pump rewire install help
Results 1 to 8 of 8
  1. #1 Racetronix fuel pump rewire install help
    Mar 2014
    Bolingbrook, IL
    00 GTP, installing the Racetronix rewire and ran into a problem and got stuck there. I ran the wiring under the car pretty easily but when I went to connect the 2 square shaped connections to the factory wiring, I got stuck.
    I left the 2 factory connections plugged into the fuel pump, tried pulling those wires to see where I connect the 2 racetronix connections, but I could only pull the factory wiring so much and couldn't pull them any more. I took a pic showing where I got stuck at.
    Can anyone please help and tell me where I'm messing up at, or what I'm doing wrong.
    Thanks
    Also, just realized I don't know how to post pics posting from my cell phone. Any help with that also, please.
  2. #2 Re: Racetronix fuel pump rewire install help
    GTP Level Member
    Jan 2015
    Lincoln, NE
    http://www.grandprixforums.net/threa...rewire-project
    look at this thread. i posted pictures of the connections and how to hook them up. look at the pictures with the red car.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: Racetronix fuel pump rewire install help
    Mar 2014
    Bolingbrook, IL
    I looked at the pics but i still can't find a ny square connections to match the 2 connections on the rewire kit.
  4. #4 Re: Racetronix fuel pump rewire install help
    GTP Level Member
    Jan 2015
    Lincoln, NE
    thats because it appears someone has performed a hack job on your harness...that is not the factory connection.
  5. #5 Re: Racetronix fuel pump rewire install help
    Mar 2014
    Bolingbrook, IL
    How can i go about correcting this?
  6. #6 Re: Racetronix fuel pump rewire install help
    Mar 2014
    Tucson
    That is the GM "upgraded" connector. Any aftermarket fuel pump module will have the "4-flat" and come with a new end to splice into the factory harness. Your original "4-square" connector goes in the trash.
  7. #7 Re: Racetronix fuel pump rewire install help
    GTP Level Member
    Jan 2015
    Lincoln, NE
    well in that case i would say go junk yarding and get a factory end to the harness.
  8. #8 Re: Racetronix fuel pump rewire install help
    Mar 2014
    Tucson
    If you do find a car that hasn't had the pump replaced, try to get that entire harness section. It runs from the fuel pump module in between the tank and trunk floor to that junction box/plate on the passenger side of the trunk floor. That way, it will be plug and play. No splices.
    I have that harness in a drawer somewhere. I can get pictures of it, and both ends if you need.
  1. FS: TOGS, GenV, Racetronix pump+rewire and more..
    By jdredd in forum For Sale - Parts
    Last Post: 11-09-2014, 05:24 PM
  2. Racetronix Fuel Pump Rewire
    By Silver2kgtp in forum For Sale - Parts
    Last Post: 08-07-2014, 03:04 PM
  3. GM Racetronix Pump rewire kit / will it work for the 04+ cars?
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2013, 10:53 AM
  4. Racetronix fuel pump install problem
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-23-2013, 12:50 PM
  5. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
