Thread: Evap Leak
Results 1 to 18 of 18
  1. #1 Evap Leak
    May 2012
    Canada , Sarnia
    On my 04 grand prix had the engine light on so hooked up my code reader and got P0446 and read it can be the evap solenoid canister so went and got a new evap solenoid just want to make sure I got the right part went to the gm dealer and got the part with a upgraded hareness part # 20941985 just got to wait to warm up outside
  2. #2 Re: Evap Leak
    is that for the top of the canister in the rear quarter? if so make sure the tank has no gas in it, and that all the lines to it and the solenoid are solid.
  3. #3 Re: Evap Leak
    Enfield, CT
    Interesting.. I did the canister on Sam's old 03 with about a half tank. No issues
  4. #4 Re: Evap Leak
    i was referring to the canister tank. if its got gas inside it theres a problem.
  5. #5 Re: Evap Leak
    Enfield, CT
    ooohhhhh lol
  6. #6 Re: Evap Leak
    May 2012
    Canada , Sarnia
    did I get the right part then?
  7. #7 Re: Evap Leak
    http://www.obd-codes.com/p0446 vent solenoid. looks like the right part.
  8. #8 Re: Evap Leak
    May 2012
    Canada , Sarnia
    ok thanks another question to replace is this part located by the rear left tire ?
  9. #9 Re: Evap Leak
    sure is. its under the gas door. if you look up from under the car you'll see it.
  10. #10 Re: Evap Leak
    May 2012
    Canada , Sarnia
    ok thanks Scottydoggs try to change it tomorrow hopefully the engine light goes off after
  11. #11 Re: Evap Leak
    unplug the battery while you work on it, that will clear the code, then you just wait to see if it comes back or not in a day or two.
  12. #12 Re: Evap Leak
    May 2012
    Canada , Sarnia
    ok was going to make attempt to fix it and tryed my impact to ge the lug nuts off so got the breaker bar and got 3 off and stripped the other 2 lug nuts when I got my winter tires on don't know what they used to tighten the lug nuts but on there super tight is there anyway to remove the stripped ones?
  13. #13 Re: Evap Leak
    that sucks. not sure never had that problem. dont know if you can get a nut spliter in a wheel
  14. #14 Re: Evap Leak
    May 2012
    Canada , Sarnia
    yes it does suck all the other lug nuts on the tires came right off
  15. #15 Re: Evap Leak
    May 2012
    Canada , Sarnia
    got one of the stripped ones off just going to take it to a shop tomorrow to get a new stud and lug nut
  16. #16 Re: Evap Leak
    May 2012
    Canada , Sarnia
    the shop got it off and changed the part when I got home and cleared the engine light now to see if it stays off
  17. #17 Re: Evap Leak
    its the waiting game now. good luck.
  18. #18 Re: Evap Leak
    May 2012
    Canada , Sarnia
    Thanks now time to fix the water leaking Into my trunk from the spoiler
  1. P0442 Evap Leak Detected - ???
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 06-05-2014, 10:07 AM
  2. Evap issue? Vacuum leak?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2014, 11:22 AM
  3. Evap leak and surging in 4th
    By vtechkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2012, 01:53 PM
  4. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  5. evap leak need help
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 08:58 PM
