Also used transmission fluid instead of the prestone power steering fluid on the second round at the recommendation of the guy at aurozone
this would be 3rd one then .... trans fluid ?
u had same issue with no power steering at idle as well right ? i can do the pump in hour i need it running asap
i guess i will replace pump again .....
so i just turned wheel 15 times with off and then on and micro bubbles were seen in the power steering fluid .... meaning air still in the system and i can actually see fluid movement with engine on and prior never really saw it moving strange gonna keep turning wheel until no more foam or bubbles
