Thread: Ignition Switch / Key
Results 1 to 4 of 4
  1. #1 Ignition Switch / Key
    May 2012
    Jacksonville, Fl
    I have an 02, 145,000 miles, runs like the day I purchased her new in Nov 02. As of about 4 hours ago what I am not able to do is turn the key to the "OFF" position. I am able to turn it to "almost off" and remove the key and all the dash lights go off so " I think " I have shut off all the power. Guess I will find out in the morning if the battery still has power. The way things are now I do not need a key to crank the car, I can turn the ignition switch without the key in it and crank the car and turn the car off, I just can not turn the ignition switch to the lock position. Making sure I lock the car doors is not the school solution.
    Thanks to all in advance for your assistance. Bill
  2. #2 Re: Ignition Switch / Key
    try some graphite lock spray. sounds like the tumbler is getting dry.
  3. #3 Re: Ignition Switch / Key
    May 2012
    Jacksonville, Fl
    Thank You, tried that yesterday with not luck, further investigation today revealed a broken purple and white wire in the plug at the bottom of the gear shift lever. A good friend came over with some of the very small pins / connectors, striped back the wire, slid it back into the plug all within about 20 minutes and the key now will turn to the lock position! However, when I open the drivers door with the key out of the ignition the chime dings until I shut the door. I don't recall it doing that before unless I had left the keys in the ignition? Any suggestions ?
  4. #4 Re: Ignition Switch / Key
    thats a common wire break at the shiftier.
    no idea why the chimes would be on with the key in your hand. thats a odd one. but as long as it stops when the doors are shut it not to much to worry about.
  1. Possible ignition switch
    By BillBoost37 in forum General Tech Discussion
    Last Post: 03-15-2013, 12:20 PM
  2. Ignition switch!?!? please help
    By Beelzeboul in forum General Tech Discussion
    Last Post: 06-11-2012, 04:19 PM
  3. ignition switch
    By mtz956 in forum General Tech Discussion
    Last Post: 08-10-2010, 04:53 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
