Thread: Sunroof issue.
Results 1 to 4 of 4
  1. #1 Sunroof issue.
    Nov 2014
    IN
    So I checked my sunroof to see if it even worked. And it does. But when I go to slide it back, it gets stuck about half way. I can keep hitting the switch repetively and it will open little by little. Then I have to do the same to close up until it reaches half way., then I can just shut it normal. Anyone ever had this problem? How do I go about fixing it?
  2. #2 Re: Sunroof issue.
    Pennsylvania
    Probably wouldn't hurt to make sure it's properly greased.
    Sport Edition Kv5 18x8
  3. #3 Re: Sunroof issue.
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    dirty track
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: Sunroof issue.
    Nov 2014
    IN
    Thanks guys. Will check it out when it's not so icy outside!
  1. '98 GT sunroof issue.
    By rpecha in forum General Tech Discussion
    Last Post: 10-23-2013, 12:22 PM
  2. sunroof issue kinda
    By locuno1 in forum General Grand Prix Discussion
    Last Post: 05-24-2013, 03:24 PM
  3. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  4. Sunroof Issue.
    By abar260 in forum Introductions/Noob Questions
    Last Post: 10-03-2011, 01:20 AM
  5. Tip: Sunroof issue fix 04+
    By Explicit_Spade in forum How To Write-Ups/Tech Tips
    Last Post: 02-19-2011, 07:11 PM
