Thread: '97 Startup Problems
Results 1 to 19 of 19
  1. #1 Re: '97 Startup Problems
    I would remove the throttle body and clean the piss outta it. Then clean the MAF sensor aswell.
    I'd also prime the pump once or twice and then remove the vacuum line going to the fuel pressure regulator. If you smell gas or see gas drip out, the diaphram inside has failed. Thus leading to longer cranks and slow/choppy starts.
  2. #2 Re: '97 Startup Problems
    Jan 2015
    Canada
    Well, this morning I was with her when she had to leave for work, car didn't start regularly. So I had her hold the accelerator a little bit, and it started right up. However there was a strong smell of gas right after startup, so I should probably be looking to replace the fuel pressure regulator?
  1. Ticking at Startup.
    By ShadowSwept in forum General Tech Discussion
    Last Post: 10-01-2013, 02:13 PM
  2. Fan Startup
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 09:15 AM
  3. Need Help; Several systems problems at startup. Video included.
    By tjslosson in forum General Tech Discussion
    Last Post: 09-29-2009, 08:04 AM
  4. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  5. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
