Thread: 2002 Grand Prix GT rough idle questions:
Results 1 to 3 of 3
  1. #1 2002 Grand Prix GT rough idle questions:
    Dec 2014
    Saint Louis, Missouri
    Hey all! New to the forum and a new Pontiac owner myself. I have a 2002 Grand Prix GT with a rough idle issue that is starting to get on my nerves, but before I buy all the sensors the code reader requires, I thought I would see if any of you had a similar problem and had a different fix to it.
    Here is what is going on:
    At start-up, it revs high, then falls to around 500 RPMs and continues surging about 300 RPMs around idle. Occasionally, it will die.
    When coasting to a stop, it will surge about 500-600 RPMs. When it is under a load, or driving normally, say with the cruise control, it runs perfectly.
    Here is what I have done so far:
    Replaced MAF sensor as asked to do by code. Code still shows up when reading them even after replaced, but indicated low voltage to the sensor. This helped out the issue, but didn't resolve it.
    Replaced PCV valve (it was stuck)
    Cleaned EGR valve (It was sticky)
    Here are the codes:
    P0102
    P0135
    P0141
    P0443
    I also have some wires between the valve cover and the firewall that are not hooked to anything. It is a 3 prong connection, part of it runs down to the o2 sensor. I am not sure if it goes to anything because I have nothing to compare it to.
    Cheers!
    Walt
  2. #2 Re: 2002 Grand Prix GT rough idle questions:
    There is a fuse to check in the fuse box that can deal with a low voltage to the MAF sensor, if that checks out then I would replace the wire/connector going to the MAF. It's kinda common for to become damage or just be faulty from age and heat getting to them.
    That can surely cause a rough idle situation if it's not working correctly..
    That 3 wire connector in the back is for cali emissions cars, dont worry about it as your car likely doesnt hae them.
  3. #3 Re: 2002 Grand Prix GT rough idle questions:
    Dec 2014
    Whoop! Fuse was stuck in just crooked enough to not make the connection. Why is it always something so simple?
  1. 1995 Grand Prix GTP 3.4 DOHC rough idle and miss.
    By 67GTO in forum General Tech Discussion
    Last Post: 08-18-2014, 09:41 AM
  2. Replies: 8
    Last Post: 03-09-2013, 12:32 PM
  3. 2002 grand prix running rough! (Please Help)
    By hobie728 in forum General Tech Discussion
    Last Post: 12-18-2012, 04:29 PM
  4. Noob with a new(to me) Grand Prix-- Rough idle question
    By awildryan in forum Introductions/Noob Questions
    Last Post: 10-29-2012, 10:18 PM
  5. 1990 Pontiac Grand Prix LE Rough Idle!!?!!
    By 90blackgrandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-13-2010, 09:38 PM
