Thread: Dynomax 53202
Results 1 to 14 of 14
MrGPHappy Dynomax 53202 12-23-2014, 07:58 PM
smoke14 Re: Dynomax 53202 12-23-2014, 10:10 PM
ItHurtz Re: Dynomax 53202 12-23-2014, 10:11 PM
theaceofspades Dynomax 53202 12-23-2014, 10:21 PM
Fivefingerdeathpunch Re: Dynomax 53202 12-23-2014, 10:34 PM
MrGPHappy Re: Dynomax 53202 12-24-2014, 12:22 AM
ItHurtz Re: Dynomax 53202 12-24-2014, 12:27 AM
Fivefingerdeathpunch Re: Dynomax 53202 12-24-2014, 12:29 AM
MrGPHappy Re: Dynomax 53202 12-24-2014, 12:42 AM
ItHurtz Re: Dynomax 53202 12-24-2014, 12:48 AM
MrGPHappy Re: Dynomax 53202 12-24-2014, 12:52 AM
ItHurtz Re: Dynomax 53202 12-24-2014, 12:56 AM
MrGPHappy Re: Dynomax 53202 12-24-2014, 12:58 AM
ItHurtz Re: Dynomax 53202 12-24-2014, 01:03 AM
  1. #1 Dynomax 53202
    Aug 2014
    Euless, TX
    I have a 06 grand prix gt and I was just wondering if I can weld these to fit onto my car w/o any modification all sites say it wont fit but I was certain the catback was the same on 97-08 models
    on another topic what is the highest flowing muffler available for our cars I have a bad KR problem and I am almost 100% certain its the exhaust that is causing it
  2. #2 Re: Dynomax 53202
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  3. #3 Re: Dynomax 53202
    Antioch, IL
    I am 100% certain your catback isnt causing any kr
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Dynomax 53202
    Aug 2013
    McDonald PA
    I can almost 100% tell you it's your plugs and your stock manifolds
  5. #5 Re: Dynomax 53202
    I agree with that last two posts, unless you are pushing over 300whp the stock catback isnt causing a exhaust flow issue.
    The front manifold and small diameter downpipe can be the bigger issue.
    But we don't know that you have done to the vehicle.
  6. #6 Re: Dynomax 53202
    Aug 2014
    Euless, TX
    I know i need to do the headers and I already chose the ones I want to go with I am just trying to plan out the rest of the exhaust setup, I want a very free flowing setup but still want it to sound nice and I dont see paying 700 for a catback when I can spend less then 300 if I do it myself
    I have 42.5# injectors coming soon
    103 spark plugs
    1.9 rockers
    machined lower intake
    3.3 pully
    S2 zzp intercooler
    catless downpipe
    egr delete
    cai with 4" cone filter
    185 tstat
    and if I am not at 300whp I am getting close, a buddy of mine has a cobalt ss sc that when last dyno'd was at 300 and I keep up with him
  7. #7 Re: Dynomax 53202
    Antioch, IL
    with a cam you might hit 290-300whp
  8. #8 Re: Dynomax 53202
    In reality, everything sounds pretty bad on a 3800.
    Borla, stock and it might have been a dynomax muffler that sounded okay. Otherwise the rasp and drone of flow crappers and some magnaflow just sound terrible.
    With those mods, which it's a decent list is likely somewhere around 250-260 at a guess. You'd need something like a 2.8 pulley with E85 to make over 300 WHP on a stock camshaft.
    You can keep up with alot of cars because you have torque, lots of torque. And that cobalt needs some driver mod, 300 whp in a little car should fly.
  9. #9 Re: Dynomax 53202
    Aug 2014
    Euless, TX
    ok simple question can I make the dynomax 53202 y transition piece fit on my car? in the end that's all I want to know
  10. #10 Re: Dynomax 53202
    Antioch, IL
    You can make anything fit with a welder.
  11. #11 Re: Dynomax 53202
    Aug 2014
    Euless, TX
    will it be a simple weld though or is it going to take some modification to make it work? I don't want to buy it then have to fight with it to make it work you know? I have had enough problems with this car as it is, downside is it is my daily driver so I like to know what I am getting into first
  12. #12 Re: Dynomax 53202
    Antioch, IL
    Says its a direct replacement, I have no clue if the end of the pipes will slip over the rest or butt up
  13. #13 Re: Dynomax 53202
    Aug 2014
    Euless, TX
    so the 97-03 and 04-08 are the same exhaust setup?
  14. #14 Re: Dynomax 53202
    Antioch, IL
    yup, I have the 04+ truebends/mandrel bends catback on my 2000
  1. dynomax vt
    By 2005GrandPrix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2011, 09:52 AM
  2. magnaflow or dynomax???
    By BadAssGTP02 in forum General Tech Discussion
    Last Post: 10-09-2011, 08:32 PM
  3. Dynomax Muffs
    By misterman in forum General Tech Discussion
    Last Post: 05-09-2011, 02:16 AM
  4. dynomax
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 09:49 PM
  5. Dynomax Muffler
    By extreme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2010, 08:07 AM
