Thread: Diagnose P0420 - HPT Scan Link
Results 1 to 6 of 6
  1. #1 Diagnose P0420 - HPT Scan Link
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Click Here for Scan
    Have the very common P0420 scan on the new Impala I bought. I'd appreciate it if some of you had a look at this scan with HPT and give me an educated opinion on the cause of the problem. I added the downstream O2 sensor to the main table so both O2 sensors would be logged.
    Car is a 2004 Impala LS (N/A 3800SII)
    The huge KR spike at WOT might be from having a bad motor mount plus a dogbone mount that's cracked in two. Motor moves around more than it should.
    Thanks in advance.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Diagnose P0420 - HPT Scan Link
    Please read up on the 420, it's most likely caused by a bad or aftermarket cat.
  3. #3 Re: Diagnose P0420 - HPT Scan Link
    Arizona
    You only need to log bank 1 sensor 1. Bank 1 sensor 2 is only to monitor catalytic performance.
  4. #4 Re: Diagnose P0420 - HPT Scan Link
    Knoxville, TN
    Quote Originally Posted by 91parkave View Post
    What I am trying to establish, is if the catalytic converter is indeed the culprit, or a lazy/rogue O2 sensor is giving false readings. You are exactly right, the downstream O2 monitors catalyst efficiency... that's why I want to verify that the sensor is working properly.
    I understand that more than likely, it's a bad cat... but I just want confirmation that it's not an O2 issue before I spend the money replacing the cat.
  5. #5 Re: Diagnose P0420 - HPT Scan Link
    Arizona
    Itd be hard regardless to tell which one because of the lack of exhaust flow due to a j a cred up cat would cause lazy oscillations on the chart display as well as a lazy 02 sensor wI'll cause the same issue.
  6. #6 Re: Diagnose P0420 - HPT Scan Link
    Knoxville, TN
    Absolutely agreed, I was just hoping someone would be able to look at the scan and saw or understood something that would be a giveaway.
  1. Help Diagnose my clunk
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2014, 05:53 AM
  2. I can't diagnose what's wrong with my car
    By metalexa1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-03-2012, 05:21 PM
  3. Diagnose my problem please
    By skeelo58 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 12:21 AM
  4. Impossible To Diagnose
    By 01Romano in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 06:19 PM
