Thread: Scanner Cant Connect to ECU?!?
Results 1 to 5 of 5
  1. #1 Scanner Cant Connect to ECU?!?
    Milwaukee
    I been having issues with my ABS and TCS lights being on and im finally getting around to fixing it. I sent my ABS module out to be fixed at ModuleMasters and I just got it back. Went to install and lights stay off until I turn my wheel. So I grabbed the scanner which reads ABS to see the codes and I keep getting an error saying cant connect to ECU. It connects to PCM and I can read and erase codes just fine. I checked the one ABS fuse under the hood and its good. Any ideas?
    2003 Galaxy Silver Limited Edition GTP
    Mods: 2.8 MPS | S2IC | XP CAM | GEN V | 65# | E85 | TOGS | N* TB | HPT PRO | Impala Brakes | BUILT TRANS w/3.29 GRS
    23° Timing...12.0 AFR...356 WHP
  2. #2 Re: Scanner Cant Connect to ECU?!?
    Sep 2011
    MI
    use a different scanner. Often times my Matco Scanner(which is supposed to read ABS) one wont read ABS and I have to borrow my friends modis.
  3. #3 Re: Scanner Cant Connect to ECU?!?
    ECU is typically considered an Engine Control Unit BTW
    An 03, I'm thinking the same.. need a higher end scanner.
  4. #4 Re: Scanner Cant Connect to ECU?!?
    Milwaukee
    That's just the error im getting when trying to access the Chassis part of my scanner where you go to read ABS. "cant connect to ECU" I checked the scanner and read my Nissan maxima with no issues. Ill have my buddy take a look with his scanner thanks.
  5. #5 Re: Scanner Cant Connect to ECU?!?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    97-2003 grand prixs are unicorns when it comes to abs / srs systems. Some sick individual made it use some bastardization of half a can bus to talk to them.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. OBD2 Scanner wont connect to ECU. . .
    By KIRKADAMS in forum General Tech Discussion
    Last Post: 07-09-2014, 04:03 PM
  2. Scanner can't connect to ABS.
    By tmgray01 in forum Brakes/Suspension/Chassis
    Last Post: 08-20-2012, 07:46 PM
  3. Connect to scanner?
    By 96markviii in forum General Tech Discussion
    Last Post: 05-02-2012, 07:49 PM
  4. Scanner Doesn't Connect To ECM
    By grandamle91 in forum PCM Tuning
    Last Post: 06-25-2011, 10:39 AM
  5. Facebook Connect?
    By JDCMoney in forum Off Topic Discussion
    Last Post: 10-28-2009, 10:26 AM
