Thread: pinhole/puncture in the rack and pinion boot.
Results 1 to 5 of 5
  1. #1 pinhole/puncture in the rack and pinion boot.
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I was doing some work near the rack and I noticed a drip. It is a small hole or puncture in the boot. It looks similar to the hole when you get your blood taken. It is located on the part of the boot that is easily seen.
    Is there anything I can use to seal this? tire patch? some type of paste? It is right on the tip. I thought about heating the puncture so the rubber may melt a bit and seal itself. But i wanted to ask first.
  2. #2 Re: pinhole/puncture in the rack and pinion boot.
    that boot is a dust boot, no fluid should be in there. so that being said, its time for a new rack soon.
    you can try some rack fluid with sealer in it, may help add some time.
  3. #3 Re: pinhole/puncture in the rack and pinion boot.
    Aug 2012
    Chicago
    its where the inner tie rod goes into the rack its fluid coming out, especially once it is started. I may have actually punctured it myself
  4. #4 Re: pinhole/puncture in the rack and pinion boot.
    like i said, thats a dust boot, not a fluid boot. if the boot is leaking the rack is dead. the end seal is leaking. not worth rebuilding.
  5. #5 Re: pinhole/puncture in the rack and pinion boot.
    Aug 2012
    Chicago
    thanks. I see now what you meant.
  1. changing rack and pinion boot 2000 gtp
    By john cola in forum General Grand Prix Discussion
    Last Post: 09-21-2012, 03:09 AM
  2. Rack and Pinion Help???
    By ill12will8 in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2012, 03:34 PM
  3. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  4. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  5. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
