Thread: Plastic Smell [HEATER]
Results 1 to 12 of 12
  1. #1 Plastic Smell [HEATER]
    SE Level Member Pontiacmaster81's Avatar
    Jan 2014
    New York
    So recently Buffalo NY had a massive snow storm past week. So I went to go start my car that was engulfed with snow all around it. I made sure to get out the Exhaust Tip so it would not seep inside. I turned the heat on full blast, while I'm outside trying to dig out this massive snow automotive. Came inside the car to get warmed up and noticed a mild plastic rubber smell. Yet it went away after I turned the heater off. I noticed that the HVAC Blower Motor underneath the passenger dash the wiring is really outdated. Meaning if you move the wire to much the Blower Motor turns off and no heat come out. So I don't know if it's the Heater fan/motor assy that's causing this distinct order or something else.
    Also on the Electrical-Switch & Relay : A/C and Heater Control Switch the A/C button does not work. you can press and press and hold it in but A/C don't turn on. So maybe this is another reason for the smell or perhaps it's both
    Any thoughts
    2002 PONTIAC GRAND PRIX GT
    "LISTEN! CAN YOU TELL THE DIFFERENCE BETWEEN
    A CAR WITH A BAD TRANSMISSION, AND ONE THAT IS POSSESSED BY A DEMON FROM HELL?"
  2. #2 Re: Plastic Smell [HEATER]
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    What car do you have? What year?
  3. #3 Re: Plastic Smell [HEATER]
    Buffalo
    I'm from buffalo. I'm free this weekend if you don't figure it out by then
  4. #4 Re: Plastic Smell [HEATER]
    Dec 2012
    Where 4T65E's were born
    If the blower shuts off when moving the wires, there's a bad connection which leads to heat, and melting of contacts or insulation. Pull the connectors at the blower motor and resistor, make sure they're not melted. I'd bet one of them is. GM isn't known for making good electrical connections... I've made many repairs in situations just like that on many gm vehicles.
    Sold.
  5. #5 Re: Plastic Smell [HEATER]
    Jan 2014
    New York
    ok I just got done changing the Blower motor, Blower Motor Control Module / Resistor, brand new Heater Blend Door Actuator, Blower Motor Connector 7-WAY FEMALE, and a new A/C and Heater Control Switch.
    1: A/C Button still does not work or turn on
    2. The plastic smell is now 10x worse then ever.
    I can't even turn the heater on. I doubled checked the electrical wires, took the dashboard completely off to check the Temperature Door and the Valve Vent nothing seems to be in the way. Also noticing that the rear window defrosted if left on for along time turns off. Don't know if it's a safety feature. But nevertheless I could use some help here. I own a 02 Grand Prix GT non-Supercharged
  6. #6 Re: Plastic Smell [HEATER]
    no idea on the heater smell. but the rear defroster will turn off on its own.
  7. #7 Re: Plastic Smell [HEATER]
    Enfield, CT
    the plastic smell is the spygate tapes melting in your car.....
  8. #8 Re: Plastic Smell [HEATER]
    Jan 2014
    New York
    Quote Originally Posted by HighOctaneRacing View Post
    You know I believed you for a second thinking it was something in my car and it's a joke.. failure on my end
  9. #9 Re: Plastic Smell [HEATER]
    Enfield, CT
    lol glad you can take a joke
  10. #10 Re: Plastic Smell [HEATER]
    Jan 2014
    New York
    I don't know what the issue is I'll look around in my engine bay for pieces that may be touching the motor, wire harnesses that are out of place or something. It could also be the ductwork inside my dash that has come loose and is resting against my heater core. It could get hot enough to melt plastic. I also could be some oil spilled on the exhaust pipe whenever it heats up
    Too many possibilities to list. I'll will have to do a thorough inspection myself or take it somewhere.
  11. #11 Re: Plastic Smell [HEATER]
    Jan 2014
    New York
    Never mind I found this perpetrator
    I could not find any plastic attached to the exhaust system, I checked and sniff around each of my wheels because the burning plastic odor can be caused by brake pads or linings that are burnt due to a parking brake that left on unintentionally or brakes that are not working properly. And sure enough I need new Rotors and brake pads along with Calipers. Thanks for helping guys
  12. #12 Re: Plastic Smell [HEATER]
    Dec 2012
    Don't see how that could be the cause if you smelled it before driving it.
    Sold.
  1. Slight coolant smell when heater is on
    By K Kraziee in forum General Tech Discussion
    Last Post: 11-23-2013, 08:16 PM
  2. Loud clunking sounds like plastic hitting plastic
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 07:50 AM
  3. Amp Gets really hot and smell a burning smell?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2012, 03:13 PM
  4. High pitched ringing sound and burning plastic smell
    By MNGPGT in forum General Tech Discussion
    Last Post: 12-27-2011, 04:06 AM
  5. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
