Thread: pull to right under acceleration
Results 1 to 15 of 15
04lss pull to right under... 11-16-2014, 06:47 PM
Scottydoggs Re: pull to right under... 11-16-2014, 06:54 PM
coolone Re: pull to right under... 11-16-2014, 08:11 PM
04lss Re: pull to right under... 11-16-2014, 09:04 PM
04lss Re: pull to right under... 11-17-2014, 06:34 AM
Scottydoggs Re: pull to right under... 11-17-2014, 08:33 AM
04lss Re: pull to right under... 11-17-2014, 08:55 AM
Scottydoggs Re: pull to right under... 11-17-2014, 08:59 AM
04lss Re: pull to right under... 11-17-2014, 10:39 AM
Ridin ON Chrome Re: pull to right under... 02-13-2016, 09:37 PM
Scottydoggs Re: pull to right under... 11-17-2014, 10:45 AM
Frosty Re: pull to right under... 11-21-2014, 10:10 AM
Fivefingerdeathpunch Re: pull to right under... 02-13-2016, 09:40 PM
Ridin ON Chrome Re: pull to right under... 02-14-2016, 12:08 PM
Scottydoggs Re: pull to right under... 02-14-2016, 12:19 PM
  1. #1 pull to right under acceleration
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So the gtp is finally on the road. I have had some fun with the gas... and ive noticed that under heavy throttle, it pulls to the right, and when you let off it jerks to the left.
    I was told the front right outer tie rod has movement in it and needs to be replaced, im thinking this might be the cause but im not sure.
    The alignment doesnt seem too far off, but again not positive. the only other cause i can think of was that my brother said the rack and pinion has a bolt that sometimes comes loose.
    any thoughts?
  2. #2 Re: pull to right under acceleration
    replace bad parts, replace that rack bolt, cause f that crap. get it aligned. should help out.
    mix matched tire brands will do this also. as well as one soft tire.
    and we all suffer from torque steer. jumping on the gas will make it pull to one side or the other some.
  3. #3 Re: pull to right under acceleration
    Nov 2011
    NY
    Had bad torque steer until new struts, springs, LCA's, sways, bushings, strut tower braces... Then gone! Lolz...
    *not saying you'll have to do that, just that worn suspension components are less resistive to the forces exerted on them, be it torque steer or cornering/handling.
  4. #4 Re: pull to right under acceleration
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by coolone View Post
    well the black boat did just hit 206k I think the struts were done at 150. Ill see what its doing after the tierod ends are replaced.
  5. #5 Re: pull to right under acceleration
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by 04lss View Post
    I was driving the car today , and it seems more like the steering is moving around rather than pulling to one direction. My Monte had torque steer but it was consistent. This also acts weird when the wheel turns sharp
  6. #6 Re: pull to right under acceleration
    if your tie rods are tight. it could be the rack its self. i just changed mine due to internal slop in the rack.
  7. #7 Re: pull to right under acceleration
    Sep 2014
    Richmond Virginia
    One of the tierods has movement in it, which i plan to replace this weekend. I just wasnt sure if that could be the culprit of if i need to order some more parts
  8. #8 Re: pull to right under acceleration
    just go over all the rack and rods, theres 2 per side, a inner and outer rods. they both can fail.
    with both front wheels off the ground with a friend pushing and holding one wheel, i could feel the other side was tight, same for the other, but if i pushed the one side in and out, the other wheel moved with it, yet the steering wheel was not moving a one bit. all slop inside the rack. and boy oh boy was it pulling hard. like into the next lane.
  9. #9 Re: pull to right under acceleration
    Sep 2014
    Richmond Virginia
    where do you get a new rack from?
    When you let off throttle did it jerk in the oppisite direction?
  10. #10 Re: pull to right under acceleration
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Old post, but this made me want to reply.
    Recently the TQ steer in my car had been really bad. I've always had it and know what it but it's come to point where I can't even control it. If I get on it from a roll it will immediately go right and I correct it and the try to over corrected and so on. I look like I'm driving drunk...lol
    Now I'm not sure if this is related but when I take off from a stop I feel my whole motor/trans move back. Then when coming to stop it will move again. Also hear a loud screech noise at the time when this happens. For sure something metal on metal is rubbing.
    I really haven't had time to fool with, so just seeing if anybody had any ideas. I do plan on jacking it up tomorrow to see if anythings lose.
    Control arms, struts, strut mounts, outer tie rods etc are pretty new. I mean there YEARS old but I only drive my car a couple 1000 miles a year.
    I really hope it has nothing to do with the rack or axles. That's pretty much the only thing I haven't changed and not to knowledgeable on changing.
    I first thought it was the rack at first because my steering had been pretty hard to steer for a long time but I'm really don't know.
    Thanks
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  11. #11 Re: pull to right under acceleration
    its always pulled a bit, i had installed a used rack 3 years ago or so. now since ive added a few mods it really started to pull, and yes, pull hard to the right, let of correct it get back in the gas and its now pulling hard the other way. it was a crap shoot what way it would pull when you first got in the gas.
    this new rack i got from napa. tightened the front end up good.
    i could also feel a click if i touched the drivers side front wheel, car off reached in key to run and rocked the wheel back and fourth. this turned into a loud click where the steering shaft meets the rack when rocking the steering wheel.
  12. #12 Re: pull to right under acceleration
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Definitely suspension related assuming you have the same tires on both sides of the car. Our cars have almost equal length axles so torque steer is minimal in my experiance. Try driving a car with one crazy long axle and one shorty. That is torque steer.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  13. #13 Re: pull to right under acceleration
    Maybe the motor mount is shot, that will allow the motor/trans to move around alot.
  14. #14 Re: pull to right under acceleration
    Houston/Baton Rouge
    I forget to add I changed the lower mount last year. The trans mount is about 10 years old.
    But after I posted this had me thinking that maybe jacking up motor so high to get the motor mount out, that maybe I messed up the trans mount. Going to see today.
  15. #15 Re: pull to right under acceleration
    check the strut mounts, aka upper dog bone mounts to the rad support.
    pop the hood have some one shift in and out of gear so you can watch the engine.
    if you have oil leaks the motor mount could be dead already.
  1. Little pull vs a RX8
    By JDrach in forum Track Sessions and Kills
    Last Post: 09-27-2012, 08:44 PM
  2. 4T65E I think its done. No pull now.
    By Brian99SE in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2012, 10:05 AM
  3. Pull not push...
    Last Post: 05-27-2011, 02:22 AM
  4. 0-105 mph pull
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-02-2010, 09:32 AM
  5. got pull over today
    By nemesis in forum The Rant Forum
    Last Post: 06-25-2009, 02:59 PM
