Thread: No cruise control or interior lights, fuses good, possibly wiring.
Results 1 to 6 of 6
  1. #1 Re: No cruise control or interior lights, fuses good, possibly wiring.
    Sounds like you are saying that someone has added wiring and you aren't sure what they did with that added wiring. Would that be correct? PRobably the best way to figure it out would be to find out which wires they tapped into. By testing the wiring you mentioned, you didn't actually get a true understanding of the wiring that was done.
    Interior lighting, possibly cruise likely both go through the bcm
  2. #2 Re: No cruise control or interior lights, fuses good, possibly wiring.
    Nov 2014
    USA
    It doesn't appear that any wiring has been added or tapped in to. Everything looks OEM except for that jumper wire in the fuse box between brake light fuse and HVAC high fuse that makes my OBD port, brake lights, and interior lights work. I don't know why they don't work without that jumper. If I remove that jumper I get intermittent OBD port and brake lights, and no interior lights at all.
    The pink and brown wires that lead up to the CC box appear to be cut but I don't know where they led to under the dash. They are bundled with the brake light switch wiring, but there is nothing in that area that looks like it is missing two wires. If I can figure out where these go I'm sure the cruise control would work. One theory I have is that they originally went to the brake light switch, but a previous owner swapped the switch out with one that doesn't have a spot for those two wires. I thought of this because that brake light switch is very loose like it has been messed with. Without seeing another car like this, or having someone tell me where those wires go, I'm not sure I'll be able to sort this out easily. Haynes diagram for CC definitely did not help.
  1. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  4. 98 GP.. Wiring schematic for overhead / interior lights
    By airboss in forum General Tech Discussion
    Last Post: 07-10-2012, 03:22 PM
  5. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
