Thread: remove instrument cluster
Results 1 to 5 of 5
  1. #1 remove instrument cluster
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi, a few of the lights in the instrument cluster are out on my GTP.
    i wanted to pull it out and see if i could either replace them, or replace the cluster (since the speedo is off anyway)
    whats involved in removing the instrument panel? I know the lower dashboard needs to come off, the pieces under the steering wheel, and the section around the radio, is there anything else?
  2. #2 Re: remove instrument cluster
    Mar 2012
    NC
    Umm...you don't need to remove column trim. But the other parts yes.
  3. #3 Re: remove instrument cluster
    Sep 2014
    Richmond Virginia
    is it about the same process as removing the radio? Im just wondering if the dashboard needs to come out
  4. #4 Re: remove instrument cluster
    the plastic trim around the dash comes off, its all push clips, so you start at a corner and work your way around popping it free.
    then theres 4 screws holding the cluster in, and a plug on the back of it.
  5. #5 Re: remove instrument cluster
    Sep 2014
    Richmond Virginia
    awesome i did this a bunch of times on my montecarlo to pull the radio out, should be pretty straighforwad.
    Thanks!
  1. instrument cluster LED's
    By 01GT guy in forum Visual/Body Modifications
    Last Post: 10-22-2013, 08:12 AM
  2. ? About Instrument Cluster
    By KoldAsIce in forum Visual/Body Modifications
    Last Post: 06-05-2013, 05:58 AM
  3. Instrument Cluster
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 12-31-2012, 05:54 PM
  4. Instrument Cluster Help
    By millerlite64 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2012, 02:25 PM
  5. instrument cluster
    By 97detgp in forum General Tech Discussion
    Last Post: 06-01-2009, 09:57 AM
