Thread: Power Steering Pump recommendations
Results 1 to 19 of 19
  1. #1 Power Steering Pump recommendations
    Nov 2011
    Michigan
    2006 Pontiac Grand Prix Base, 165k
    This is my second time replacing my power steering pump in 10 months, the first one cracked and now the second one that I just installed yesterday sounds like a defective pump (Grind noise turned wheel all the way to the left). This pump I bought at Autozone is a Duralast and I'm starting to think they are not very reliable pumps. Does anyone have any recommendations? MasterPro? I would like to go pick one up after work today.
    Thanks.
  2. #2 Re: Power Steering Pump recommendations
    Jul 2012
    Chicago
    Grab an ACDelco off of Rockauto
    -Carl
  3. #3 Re: Power Steering Pump recommendations
    Pennsylvania, USA
    Some things are just better going OEM with. PS pump, coil packs, etc. If you're strapped for cash, Morad Parts probably has a used PS pump for cheap.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  4. #4 Re: Power Steering Pump recommendations
    Psssh I'll stick with the cheapo ones from advance. Exchanges are easy and with online coupons a pump is cheap. Oh plus the pumps rather easy to change.
    04 Comp G.
  5. #5 Re: Power Steering Pump recommendations
    im using a duralast p/s pump for like 3 years now, its dead quiet. any pump. idc who makes it, the pump will whine when you pull the wheel to the lock and hold it all the way.
  6. #6 Re: Power Steering Pump recommendations
    Enfield, CT
    They generally use Cardone lol. If the side of the box is red and blue lines with writing, it's cardone
  7. #7 Re: Power Steering Pump recommendations
    Dec 2012
    Where 4T65E's were born
    My stock pump doesn't whine at all when turning or at the locks. Except when it gets below freezing though. I think it's original.
    Sold.
  8. #8 Re: Power Steering Pump recommendations
    Grand Rapids, MI
    I had bad luck with a reman. a1 cardone from Rockauto. I ended up buying one from Morad and it was golden. It was used but... worked beautifully.
  9. #9 Re: Power Steering Pump recommendations
    Jul 2012
    Chicago
    My pump never whines, not even hard against the lock.
    -Carl
  10. #10 Re: Power Steering Pump recommendations
    Dec 2012
    Maybe try your luck and run an inline p/s filter for a week and see if that helps prevent a whine. Although I don't think that's an indication its worn out.
    Sold.
  11. #11 Re: Power Steering Pump recommendations
    Pennsylvania, USA
    I got mine to run silently in below freezing weather by running Mobil1 synthetic ATF instead of normal PS fluid, the viscosity at low temps is much better than normal PS fluid. At least I'm assuming that's why it's quiet. I flushed with normal PS fluid while I was changing the lines, and once it ran clear I sent the M1 through until it was coming out the return line. No sense in wasting expensive ATF doing the flush portion, normal PS fluid is crazy cheap.
  12. #12 Re: Power Steering Pump recommendations
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by nik12937 View Post
    That's really interesting, I've heard of cars that use ATF as P/S fluid from the factory, had no idea it had good results in our cars. I should try this.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #13 Re: Power Steering Pump recommendations
    Dec 2012
    Makes sense. I'd do that, but unfortunately the thick lucas p/s fluid that's in it is all that's keeping it from leaking lol.
    Sold.
  14. #14 Re: Power Steering Pump recommendations
    May 2008
    Schuyler, NE
    I got one from advance auto for my 04. I followed their procedure for first startup, and it always whined. Returned it, got a used one from Morad and no problems.
  15. #15 Re: Power Steering Pump recommendations
    power steering pump and rack is a hydro pump set up, just like a trans is. ive used ATF fluid for years back in the day.
  16. #16 Re: Power Steering Pump recommendations
    Knoxville, TN
    True, I just don't generally swap fluids around unless I understand the properties. I'm willing to bet that ATF handles heat much better than P/S fluid.
    P/S fluid sure is nasty stuff when it breaks down.
  17. #17 Re: Power Steering Pump recommendations
    Pennsylvania, USA
    Morad is always safe choice for used parts, I got an auto dim Gntex mirrror from him for $30 dollars.
  18. #18 Re: Power Steering Pump recommendations
    Aug 2014
    Maple Grove, MN
    get OEM pump. It's really common for them to have a little bit of whine so unless it's just horrible I wouldn't worry about it.
    Oddly enough my friend's mother has a 2003 Bonneville SSEi with 320k miles and it's still rocking the original PS pump :lol: . It also still has the original engine and trans. Damn near everything else has been messed with though. They've busted numerous mounts, alternators, coil packs, suspension bits and just recently replaced the supercharger with a junkyard replacement. They never replaced SC oil and were unaware of the common coupler failure. GM 3800 cars are weird
  19. #19 Re: Power Steering Pump recommendations
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Never had to replace ps pump, but i would always go with ac delco. Bought 2 monroe quick struts for 120$ brand new off this crazy lady on craigslist, and she threw in a 2005 impala 3800 ps pump, looks new and ac delco, and 4 rims off a 1994 grand prix. PS pumps are fairly cheap, even oem is less than a hundred bucks, and going with that in the first place would of saved you another 100
  1. power steering pump
    By ericg1181 in forum General Tech Discussion
    Last Post: 05-02-2014, 09:27 PM
  2. Power Steering Pump Going Bye Bye?
    By burgundybullet in forum General Tech Discussion
    Last Post: 02-28-2013, 11:15 AM
  3. Power Steering Pump On Its Way Out
    By Danarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2012, 01:28 PM
  4. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
