Thread: Bearing question
Results 1 to 6 of 6
  1. #1 Bearing question
    Dec 2008
    Montreal,Canada
    Again i am a complete dummy about stuff liek this but on my 2003 GP GT...are their sensors that go off when it is time to change a bearing??Reason i ask is cause on my grand am Gt it had. And i am noticing when i am turning left i feel a vibration, and only left. My girlfriend and i feel it under our feet(the vibration) but once i straighten it up,it goes away.Could this be the bearing and if so which side?? thank you for any help
  2. #2 Re: Bearing question
    TDCRacing
    Guest
    There are no bearings on our cars that have a sensor to tell you if they go bad with maybe the exception of a wheel hub. And half the time it's not even the actual bearing. Anyway with that the abs/traction lights will stay on.
    It's really going to be hard to tell what is wrong enless someone actually looks at it.
    I'm sure there will be several that chime in on this thread naming about 10 different things that could be wrong but chances are you'll just have to jack it up and climb on under there to check things out.
  3. #3 Re: Bearing question
    Bastard Reptile's Avatar
    Kansas City, MO
    It sounds like the hub bearing is going out. In severe cases when it gets bad enough to damage the sensor (which is what happened in the grand am's) then it will set a code.
    Just try taking the left wheel and rotor off to see if it has shavings coming out of it, or if it feels loose. When you spin it, it shouldn't grind or growl.
  4. #4 Re: Bearing question
    Feb 2008
    Yup^^ X2
    With what you are describing, it could be a wheel hub assembly. Like TDC said it is difficult to tell for sure without actually looking at it. However, they are a very common part that goes bad when they get some miles on them.
  5. #5 Re: Bearing question
    Dec 2008
    Montreal,Canada
    Thanks guys much apperciated. i am going to get it looked at on Monday..just have to wait till then
  6. #6 Re: Bearing question
    Donating Users chrisb's Avatar
    Bucyrus, OH
    on my car i get like a rubbing/vibration when i turn right. its nuthing crazy but it has to do with either my new swawy bar or strut bearings.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Spun a bearing
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 12:05 PM
  3. Spun bearing! swap to L26??
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 08:35 AM
  4. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
  5. Replace cam bearing with engine still in?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 09:05 PM
