Thread: Using a breather with an intercooler
Results 1 to 9 of 9
  1. #1 Using a breather with an intercooler
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I am aware of the possible issues with running a VC breather and the vacuum leaks. I have experienced this myself on some previous builds (not on GTPs though)...
    I am wondering if some of you have used a breather instead of modifying your setup with Full Stack Intercoolers? If so, what did you do to the tune (or anything else) to help combat the vacuum leak symptoms? Any other adverse effects?
    I am under the impression that the vacuum leaks really only affect the car during idle and sub-boost conditions. Under boost, the vacuum leak should essentially go away as the crankcase is under positive pressure right? so the issues would likely go away completely under boost..
    Open to thoughts and suggestions
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Using a breather with an intercooler
    hangover park IL
    yeah, except you spend very little of your time in boost, and a vst majority of time in vac conditions...with a pcm that adjusts fueling while at low TPS% (ie vac) for both low rpm and high rpm AFR.
    so really its not good, just delte pcv system and run the filter and change your oil far more often, or keep the pcv system and plub in a fresh air supply from behind the maf, but in front of the throttle blade, and you will no longer have any tuning issues.
    ive run the breather, its a pita, 10 minutes of work and for less than the cost of a breather you can retain oem type pcv operation.
    ~James~ Psychotic Gearhead
  3. #3 Re: Using a breather with an intercooler
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    Good points.. that is what I ended up doing on my vettes in the past.. Running a breather, having vacuum issues, then building a custom PCV/catch can setup and it worked the best. No vacuum issues and clean air going back into the intake track. Maybe I will deleted the manifold PCV setup and make a catch can setup going from the oil cap up to the intake (pre-TB, post-MAF as you mentioned).
    2002 GTP sedan:
  4. #4 Re: Using a breather with an intercooler
    hangover park IL
    Quote Originally Posted by 97AutoXVette View Post
    the air/oil separator is great for reducing knock tendency with not oil suspended in the recirculated air.
    this is a breather per bank setup i did on the Turbonnie. no pcv function, just oem pcv air paths to allow the oil to fall out of suspension and drain bak to the crankcase and external lines to a breather tank. hopefully he only has to drain and clean the breather tank once a year vs the vc/fill cap point which gives you tons of oil mist (aand is one reason breather cars tend to drip oil from em, enless an 04+ neck is used and its crammed with stainlesss choreboy to allow the oil to condensate on and drain down
  5. #5 Re: Using a breather with an intercooler
    http://www.grandprixforums.net/threa...7-99-gtp/page7 anthony did this pcv mod to his lim.
  6. #6 Re: Using a breather with an intercooler
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    ..... How did that guy only dyno 302 whp with cam e85 fsic and all other mods. .
    04 GTP -HAI, 1.9 rockers.
  7. #7 Re: Using a breather with an intercooler
    hangover park IL
    cause not zzp's dyno
  8. #8 Re: Using a breather with an intercooler
    Aug 2013
    Sandy, UT
    My friend dyno'd @ 329 WHP on stock cam, 1.9's FSIC e85 headers and catback on a 2.55 on a gen V... on "not zzp's dyno". But I suppose that dyno could have been off as well
  9. #9 Re: Using a breather with an intercooler
    Jul 2014
    colorado
    1) dats my car now
    2) 302 was with nothing on vehicle to measure engine Rpm, I doubt it's far off though. I wanna dyno it soon.
    3) Ic setup on this car burns oil.
  1. Second valve cover breather
    By Macksauce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2014, 04:11 PM
  2. oil in valve cover breather
    By silver3 in forum Turbo
    Last Post: 10-01-2013, 09:44 PM
  3. Valve cover breather ?
    By mikey666 in forum General Tech Discussion
    Last Post: 05-02-2013, 07:17 AM
  4. How to take rock breather out of s/c shaft?
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2012, 07:08 AM
  5. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
