Thread: Daytime running lights
Results 1 to 8 of 8
  1. #1 Re: Daytime running lights
    SE Level Member DerekD's Avatar
    Indianapolis
    The DRL's use the same lights. If they work normally any other time, I'm guessing that the relay could have gone bad. Most people disable the DRL anyway by unplugging the wiring from the relay. You can get to it by opening the little hatch at the left end of the dash. You can open the driver side door to see it. When I disabled mine, I removed that hatch and reached up from the underside of the dash to unplug the wires. I believe that there are a couple of relays there but I cannot remember what is what. You may just take a peek and see if anything is unplugged which I think is unlikely with how those connectors work.
  2. #2 Re: Daytime running lights
    Dec 2008
    Columbus, OH
    Assuming nothing is unplugged, then is it probably a bad relay? If so that's probably a more expensive repair than I'd be wanting to get.
  3. #3 Re: Daytime running lights
    Indianapolis
    Since the lights work at night automatically or when you turn them on, I wouldn't worry about it. Many have it disabled anyway. If it is indeed the relay, I wouldn't think it would be that expensive. I just wouldn't. If you ever decide to get HIDs, you wouldn't want the DRL anyway.
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
  3. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
  4. Anyone running an EGT sensor?
    By Andrew_99GTP in forum Turbo
    Last Post: 06-18-2008, 07:13 AM
  5. HELP!! My GP is Only Running On 5 Cylinders!!
    By y1a3o in forum General Tech Discussion
    Last Post: 05-14-2008, 11:20 PM
