Title says it all. 3100 engine.
thanks
thanks
Not in the air box or under it that I could see
take the filter out, it should be in the other 1/2 on the bottom. if you look at the sides of the box you should see a wire harness entering the air box.
if its anything like a 97 up car.
The PCM is in the middle of coolant box, engine, and STB, guess it is close to the coolant box.
I found it thanks
