Thread: 2004 GTP massive hesitation
Results 1 to 2 of 2
  1. #1 2004 GTP massive hesitation
    Overland Park, KS
    Well, I started the car to go home from work and it idles fine & smooth. Put it in gear to back out of parking space and massive hesitation starts when I touch the throttle. Literally like half throttle to zero and back alternation about once a second. Tach bounces up & down from zero to 3500. If I hold the throttle about half it will eventually clear itself up to accelerate. My thoughts are either the throttle or throttle body. Or the crank sensor since the tach freaks out. No check engine lights. Starts & idles fine. I know the throttle is opening at least because I could hear the supercharger whine more with it full throttle even when the engine is essentially off during the surging hesitation problem. Any other ideas? Thanks!
    04 GTP Comp G, airbox cut, no cat or resonator
  2. #2 Re: 2004 GTP massive hesitation
    Overland Park, KS
    And apparently it's sporadic. I just went out to switch cars around to drive something else tomorrow and it started & ran normally. Took it for a test drive of a couple miles, all normal. Sigh.
  1. 2004 GT - Hesitation , Missfire?
    By 04PrixxGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2012, 11:03 AM
  2. massive flat spot into third WOT
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 09:24 PM
  3. Massive Oil Leak
    By 2000superGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 11:17 PM
  4. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  5. WOAH! Massive Oil Leak!
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2010, 12:30 AM
