Thread: Tire Pressure Sensors
Results 1 to 3 of 3
  1. #1 Tire Pressure Sensors
    The Boss Iceman6669's Avatar
    Jun 2011
    In my 97 I know basically how the Tire Pressure monitoring system works. But my question is, will it cause issues if I run 17" rims in the front and 18" rims in the back?
    2011 F-150 Yote powered
  2. #2 Re: Tire Pressure Sensors
    If the tires sizes are within 1-3% then it might be alright.
    The ABS/TPMS likely needs to see a pressure drop of 5-10 lbs in the tire and the in itself changes the rolling diameter atleast over 3-5% to set the light off.
  3. #3 Re: Tire Pressure Sensors
    Jun 2011
    I just wasnt sure if it went just Right to left or if it also compared front to rear.
  1. Noob Question - Tire Sensors and After Market Wheels
    By Koopa in forum Introductions/Noob Questions
    Last Post: 04-17-2013, 04:27 AM
  2. Disable low oil and oil pressure sensors
    By DoubleBlown in forum PCM Tuning
    Last Post: 02-04-2013, 07:54 AM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  4. are these tire pressure sensors one in the same / exact same
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:18 AM
