the tank on the driver side blew, sending coolant all over the air box, Ill try undoing the ECM connector and seeing if any water comes out, im draining the water I put in the rad for leak checking to see if maybe im getting water on a spark plug, it still wouldn't explain why its misfiring when t throws the code though. but worth a shot, almost did a reset by touching the negative and positive leads together and doing a hard reset on everything
