Thread: Has anyone seen these headers before?
Results 1 to 20 of 21
  1. #1 Has anyone seen these headers before?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    http://www.amazon.com/OBX-Exhaust-Po...d+prix+headers
    Not sure if anyone has tried these. They say they are for 99-05 NA motors but I would think they would work for the supercharged L67 motors as well?? They look like they'd be a much easier install and would avoid the leaks of some of the other brands.
    exhaust runner sizes look to be just under that of the PLOG and other header options. Correct me if I am wrong though
    Let me know what you guys think.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Has anyone seen these headers before?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I don't see why they wouldn't work on SC engines. Also i would think they would work on any series 2 or 3 not just 99-05
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    I'd agree.. The question would then come down to the size of the primaries, crossover, and DP. Seem pretty close to that of other header options, just not sure if the slight difference is really that restrictive
    2002 GTP sedan:
  4. #4 Re: Has anyone seen these headers before?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Weren't OBX headers really ****ty?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: Has anyone seen these headers before?
    Jan 2012
    Indianapolis
    Can't be worse than 200 dollar ebay headers...... I would hope anyways
  6. #6 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    I'd be very curious to see how easy these OBX headers would perform and how easy they'd be to install on an L67 GTP setup
    2002 GTP sedan:
  7. #7 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    RedComp, I remember seeing/ hearing that as well. Only thing is these OBX headers are a different setup then the normal ones people refer too I believe
    2002 GTP sedan:
  8. #8 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    Yeah, I have no idea. Some of the OBX headers directly resemble the pacesetter options on Amazon/EBay.
    2002 GTP sedan:
  9. #9 Re: Has anyone seen these headers before?
    Those $200 eBay headers have been proven to fit without any or much modification.. Id stick with SD's. I remember the OBX requiring a ton of work to get them to fix correctly.. IIRC the crossover was wrong and needed to be cut and welded to get it to work..
    04 Comp G.
  10. #10 Re: Has anyone seen these headers before?
    The Boss Iceman6669's Avatar
    Jun 2011
    This. They dont fit right and end up needing modifications to fit and seal. Stay away from them. The Speed Daddy headers fit and seal without issue if you do it right.
    2011 F-150 Yote powered
  11. #11 Has anyone seen these headers before?
    They could be but you'll probably end up benign a guinea pig and seeing if they will work with little to no modification.. For that price id just stick with SDs and keep it simple. Or stick with the whole plog/dp combo like some guys do depending on ultimately your goals.
    Edit: and yes if they fit on a N/A block they will fit on a SC setup...
    04 Comp G.
  12. #12 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    all good points. Thanks for the feedback. Agreed that I'd probably be a guinea pig with these if I gave them a shot
    2002 GTP sedan:
  13. #13 Re: Has anyone seen these headers before?
    Apr 2012
    Dayton, OH
    They are different from the ebay OBX headers, the crossover is different along with where all the pipes merge. Who knows, be a guinea pig!
    2012 F150 STX
  14. #14 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    I am getting tempted... Can already tell the install should definitely be a lot easier. Only a couple pipe connections!
    2002 GTP sedan:
  15. #15 Re: Has anyone seen these headers before?
    Apr 2012
    Dayton, OH
    Assuming those pipe connections aren't hellacious off.
    2012 F150 STX
  16. #16 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    Very true.. Only one way to find out
    2002 GTP sedan:
  17. #17 Re: Has anyone seen these headers before?
    Nov 2011
    NY
    In a platform old as the one we are all working with, there are no hidden secrets left, jewels to find and what worked is getting harder and harder to find. That said, I for one would stick with what's known and good, meaning at the very least SD's... But if you're willing to go through what the OBX require to make work, why not just invest in some stainless mandrel pipes and make your own headers
    : ) hell... You might even get so adventurous you could fabricate even length tubes, thereby making our exhaust sound decent!
    now that would be worthy of ginuea pig status for sure!!!
    : ) lol...
  18. #18 Re: Has anyone seen these headers before?
    Mar 2014
    Cincinnati, OH
    Did some more searching and it looks this these are a direct copy of the S&S Headers. Same sizes and shape. Anyone ran S&S headers on a GTP with good results? I know the size seems more geared towards NA cars..
    2002 GTP sedan:
  19. #19 Re: Has anyone seen these headers before?
    Apr 2012
    Bancroft. Ontario, Canada
    SD ftmfw.
  20. #20 Re: Has anyone seen these headers before?
    Feb 2009
    flintnasty MI
    These headers suck for wbodies. I run them in all the fiero swaps I do because they are more modular and easy to mod for rwd.
    In fwd they love to leak at the y and the front manifold hits the trans really bad on at least the non obx version of these (some other company sold these for like $150 a set)
  1. WTB Headers
    By Btownmills in forum Wanted To Buy - Parts
    Last Post: 06-18-2012, 12:27 AM
  2. First mod for 98 GTP SD Headers?
    By RideWithPride in forum General Tech Discussion
    Last Post: 06-15-2012, 09:21 AM
  3. Headers
    By JonnyGrandPrix in forum General Grand Prix Discussion
    Last Post: 03-08-2012, 09:48 AM
  4. DNA headers
    By ctrout in forum Off Topic Discussion
    Last Post: 03-10-2010, 01:17 AM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
