Thread: Add dog bones to Bonnie?
Results 1 to 14 of 14
  1. #1 Add dog bones to Bonnie?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    So even with upgraded hockey puck motor mounts my engine still has quite a bit of movement on the passenger size and I want to firm it up.
    I should be able to just grab the dog bones and radiator side mounts and bolt/weld them on to the radiator support.... Right? I have both engine side mounts bc I am running grand prix cast iron bracket and i just have the other one because I'm a 3800 parts whore.
    04 GTP -HAI, 1.9 rockers.
  2. #2 Re: Add dog bones to Bonnie?
    Mar 2012
    NC
    Quote Originally Posted by SnowTh1ef View Post
    I don't see why you couldn't but I'd recommend a little extra sheet metal on the rad support though as it wasn't designed to see any engine torque.
  3. #3 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    Probably a good idea.. I'll have to look at it a little closer after work tonight to see how weak/strong it looks.
  4. #4 Re: Add dog bones to Bonnie?
    Oct 2011
    Toledo, OH
    Can't you swap in a Regal/GP radiator support as well?
    7"
  5. #5 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    I suppose thats a possibility but thats a lot more structural welding than I feel comfortable with...
  6. #6 Re: Add dog bones to Bonnie?
    Mercer, Pa
    How much motion you getting? Hockey puck is solid mount. The flex you see is the cradle to the frame mounts.
  7. #7 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    I know, but I don't want to deal with making/buying a solid or solidish mount for those places. I want to just add one dog bone on the passenger side because thats where the engine is still flexing.
    I'm guessing the flex is coming from the two mounts that look similar to the main motor mount on each side of the car, going from the trans to the body in the wheel wells.
  8. #8 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    These ones. they bolt on to the motor/tranny and on to the body on my car. one in each wheel well.
    Add dog bones to Bonnie? Attached Images
  9. #9 Re: Add dog bones to Bonnie?
    Mercer, Pa
    Quote Originally Posted by sseilmnop View Post
    My lower mount
  10. #10 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    My lower mount
    I've seen this on bonneville club. Its an awesome mount, but I was too cheap and my hockey puck one has basically no vibrations because there are 2 kinds of hockey pucks, 2 hard ones for ice on the outside sandwhiching a soft street puck in the middle :-)
  11. #11 Re: Add dog bones to Bonnie?
    Mercer, Pa
    I've seen a dog bone added to a bonneville with hockey puck mount. No welding was done.
  12. #12 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    They just bolted it to the rad support?
  13. #13 Add dog bones to Bonnie?
    Mercer, Pa
    Man was I wrong, cheaper to buy mounts.
    http://www.pontiacbonnevilleclub.com...&view=previous
    I am wondering, in the 10 years and 4 SSEi's I've had I've never replaced anything but the front lower mount.
  14. #14 Re: Add dog bones to Bonnie?
    Aug 2013
    Sandy, UT
    Hm. Might still be something I'll try and tackle. We'll see. My car already looks like a POS but its mechanically sound and moves good so I don't care. So it won't bother me if mine doesn't look factory clean. :-P
  1. V8 droptop Bonnie
    By Anthony Smith in forum Members Rides
    Last Post: 03-25-2014, 01:38 PM
  2. Bonnie GXP wheels
    By Le Patriote in forum Tires & Wheels
    Last Post: 09-19-2013, 03:41 PM
  3. Which tire should I run on my Bonnie GXP wheels
    By h0wl0ngcanitbe in forum Tires & Wheels
    Last Post: 10-16-2012, 12:21 AM
  4. GXP got hit! Q: my bonnie rim?!!!
    By Specter GXP in forum Off Topic Discussion
    Last Post: 04-22-2010, 11:27 PM
  5. Bonnie GXP wheels on Prix GXP
    By TallassJonG in forum Visual/Body Modifications
    Last Post: 10-17-2009, 11:08 PM
