Thread: NGK Tr6ix plugs
Results 1 to 20 of 22
  1. #1 NGK Tr6ix plugs
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Can't find nothing on the forum about these plugs, but if anybody has any experience with them please comment.
    Now I've ran Tr6ix years ago on the GS and they were flawless(left them at factory gap .035" I believe)
    Switched up for a minute and went with the Tr6 all copper and they were nice too (gapped to 3800performance/ZZP recommendations well close enough at .053")
    So now im going back to the NGK tr6ix iridium. though they recommend not to gap iridiums i've done it before, just not to NGK iridiums.
    So NGK iridiums come pre gapped at .035"-.039" I believe and the NGK tr6 copper are recommended around .055" give or take for max power out.
    Though the iridiums are precious metal, would I benefit from gapping the tr6ix up a bit maybe to around .045" a lil closer toward the copper tr6 range?
    Tr6ix run cooler so they shouldn't get that hot. Im currently on a 3.4" pulley about 9-10lbs boost maybe less though.
    But yeah these tr6ix have a lot to offer so im just tryna get the most out of them with a lil more gap
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: NGK Tr6ix plugs
    im running AL 104's gaped at 0.55 with a 3.4 pulley
  3. #3 Re: NGK Tr6ix plugs
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    From what I've read and understand, You'll want to stick to the coppers, Iridiums are too hot, and the copper 104s or 103s will be better for knock on modified setups.
    04 GTP -HAI, 1.9 rockers.
  4. #4 Re: NGK Tr6ix plugs
    Wichita
    If you have a Wbody you'll want TR6iX's when you have an LS4.
  5. #5 Re: NGK Tr6ix plugs
    Aug 2013
    Sandy, UT
    ...He clearly doesn't have an LS4. He has a gtp on a 3.4 pulley setup
  6. #6 Re: NGK Tr6ix plugs
    I live here. DirtDog's Avatar
    Jun 2012
    I'm running these. Nuts that's on a 5.3
  7. #7 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    Im in a GS, but have anyone gapped a tr6ix iridium? Im thinking of gapping them to .040"-.045" but ill rather know the outcome before I waste my time
    The stock tr6ix gap definitely worked the few years I ran them but im hoping for a more complete consistent combustion with a lil more gap.
    A gap of .045" on a tr6ix iridium plug shouldn't cause spark plug blow out should it? At the moment just a 3.4" pulley no more than 9lbs of boost
  8. #8 Re: NGK Tr6ix plugs
    Jun 2012
    .040 max. I'd stick with .035 personally.
  9. #9 Re: NGK Tr6ix plugs
    stock gap is .060 you maybe going to small. just putting copper plugs in my car, tr55's woke it up. the AL104's the car liked better tho. im gaped at 55
  10. #10 Re: NGK Tr6ix plugs
    Jun 2012
    My understanding is colder plug...smaller gap. And the tr6 is definitely colder than stock correct
  11. #11 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    Quote Originally Posted by DirtDog View Post
    I know that's because they're iridium, but the copper core tr6 are recommended to be gapped at .055"-.057".
    That's a nice size difference between the two plugs. Minds well stay with the copper core at .055" if I cant raise the iridiums up.
    I was just tired of the short interval of the copper cores
  12. #12 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    Yes tr6 is colder, two heat ranges according to 3800performance
  13. #13 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    Gotta be some more members on here that use NGK tr6ix iridiums
  14. #14 Re: NGK Tr6ix plugs
    Those plugs suck.
    That's why there is no one using them.
    Old motors, old technology, old school tricks work.
    High octane, low temp T-Stats, and cold copper plugs. Done and done. AL104's, gapped at .050".
  15. #15 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    Quote Originally Posted by blueguy View Post
    Those plugs suck.
    AL 104s are 1 or 2 heat ranges colder?
    So AL104s over NGK tr6 copper core?
  16. #16 Re: NGK Tr6ix plugs
    why are you running a cooler plug in the first place? your mod list in the sig dont really require them
    unless you have a 3.4 pulley on that we dont know about?
  17. #17 Re: NGK Tr6ix plugs
    Jul 2012
    North Philly
    My sig should state that I have a 3.4" pulley but if it doesn't.....in the beginning of my thread I clearly state that I have a 3.4" pulley with around 9lbs of boost
    Come on scotty read the post/thread
  18. #18 Re: NGK Tr6ix plugs
    i quit reading a long time ago, like blueguy lol
    up date your sig man.
  19. #19 Re: NGK Tr6ix plugs
    Jun 2012
    Speaking of updating sigs...mine is long over due
  20. #20 Re: NGK Tr6ix plugs
    i updated mine with in days of stuff getting put on.......
  1. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Plugs??
    By Rudd97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 07:01 PM
  4. Where do these plugs go?
    By JoRoW99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2011, 08:43 PM
  5. What plugs should i use?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2008, 02:00 PM
