Thread: "Charging system failure"
Results 1 to 18 of 18
  1. #1 Re: "Charging system failure"
    Aug 2013
    arlington, tx
    If you don't have one, I wouldn't rush out to get one if you could just take it to autozone or a parts store where they test batteries and alternators for free. Put the meter on DC V, put the red probe on the positive and the black probe on the negative on the battery with the car off and you want to see around 12V. Now turn on the car and do the same thing and it should read around 14V. That usually indicates that battery and alternator are good. It means the battery is holding a 12V charge without any assistance, if you will, and when you turn the car on, the alternator raises it to 14V. Another thing to check for is to see if the voltage is constant. When you're measuring and the voltage jumps up and down and it doesn't stay at a certain voltage, there's another issue behind it. I changed out a battery that was doing just that. It would read 12V but as soon as any load was applied to it, it would drop to 0V. Unfortunately you can't test that with a meter but the parts store should have that there. Like I said, if you can, just take it up there and have them test it for ya. It's free.
  2. #2 Re: "Charging system failure"
    Mar 2012
    Prescott, WI
    Thanks luckyg817, I will go get it tested at the store.
    2004 Grand Prix GT (215,000 miles)
    2003 Ford Ranger FX4 Level II (135,000 miles)
    2002 Harley - Fully modded
  3. #3 Re: "Charging system failure"
    Mar 2012
    Prescott, WI
    I also read somewhere that if the voltage is too high, say like 15-15.1 Volts, that is bad too? What would that cause?
  4. #4 Re: "Charging system failure"
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by FX4 Level II View Post
    04+ charging systems are completely different and will charge anywhere from 12.1 to 15.1, this is normal so don't go by any information to the contrary.
    Jeff
  1. charging system failure
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 07-19-2014, 01:30 PM
  2. Volt gauge reading high, "charging system failure"
    By Aeroheadcww in forum General Tech Discussion
    Last Post: 05-21-2014, 12:03 AM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  4. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  5. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
