Thread: 04 GTP - short in climate control fan
Results 1 to 2 of 2
  1. #1 04 GTP - short in climate control fan
    Aug 2012
    United States
    Just noticed last week that my 04 GP GTP climate control fan (AC/heat) drops in speed if I hit a large bump. Today when I came out and started the car, it was non functional so I hit the speed bump at the gym and it came back on. Any idea where I might begin my search for this short? ALSO, my internal power sources (cig lighters) haven't worked for a couple of year. Where is the likely problem there.
    Thanks for help in advance.
    Brent
  2. #2 Re: 04 GTP - short in climate control fan
    St. Louis
    There is a fuse for the cig lighter. Also controls the OBD port as well. Check for any obstructions in the power ports (change, rust) and change the fuse.
    As far as the blower motor check the harness that connects to the motor itself. Should be on the pass. side under the dash. Have the blower on and wiggle the wires going to it. If it fires up then disconnect the harness, turn blower and car off and see if you can check the pins in the harness and the wiring to them. Likely one is loose. If not, then it could be the blower itself.
  1. Climate Control from 06 in 04????
    By rodguezsciii in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2013, 09:47 AM
  2. climate control
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-19-2010, 11:04 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. climate control
    Last Post: 01-27-2009, 09:10 PM
