Thread: 97 Alt Bracket on my 1999 GTP?
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: 97 Alt Bracket on my 1999 GTP?
    The Boss Iceman6669's Avatar
    Jun 2011
    Ive literally never ever had any issues getting it out...
    2011 F-150 Yote powered
  2. #22 Re: 97 Alt Bracket on my 1999 GTP?
    i only had mine off once, it was a b1tch to get off, i had to walk away from it for a minute.
  3. #23 Re: 97 Alt Bracket on my 1999 GTP?
    Jun 2011
    The tensioner was one of the first things that I had to do on my car... And it came off fairly easy.. Then I took it off again when we did my lim and again no issues. Plus I am pretty sure the cover doesnt break you end up snapping the elbow off first.
  4. #24 Re: 97 Alt Bracket on my 1999 GTP?
    nope the out side of the cover breaks off the hole the elbow slides into.
    when i did my lim i busted the top elbow off and replaced it with the lim.
  5. #25 Re: 97 Alt Bracket on my 1999 GTP?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    he want to go the other way. 99 to a 97. bad idea lol
    Thats what im saying, ive got the old setup on my 2000.I downgraded it so i could use its newer style on my 98.Gen 5 swaps need the newer setup for alt clearance.Ive never broken the old style, evenly getting it pulled out is the key,which can be tough.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  6. #26 Re: 97 Alt Bracket on my 1999 GTP?
    No, if you try to pry it off that's what causes it to break. That's why gm redesigned it. The technicians didn't know how to take them off and would pry on them. You will never break the timing cover by wiggling the bracket out. If you do, you did it wrong.
    Sent from A Galaxy Far Far Away........
  7. #27 Re: 97 Alt Bracket on my 1999 GTP?
    I was able to keep the bigger 140 amp bonnie alt with a gen v, James mentioned he runs that step often and .. if you find the right year firechicken, it'll have a 97/98 alt looking bracket with both elbows removable.
    Wiggling the VC past is cake..
  8. #28 Re: 97 Alt Bracket on my 1999 GTP?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Are you only referring to the 97/98 style though? looking at my 99+ bracket, it looks like it hangs over the VC at least an inch or so
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  9. #29 Re: 97 Alt Bracket on my 1999 GTP?
    on the 99+ wiggling it past is really easy. I did it last week.
  10. #30 Re: 97 Alt Bracket on my 1999 GTP?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by goldgp View Post
    Im currently running my Gen V on a 97 alt no issues but eventually i will be grabbing a 99+ alt and bracket
    Sent from my LG-E980 using Tapatalk
  11. #31 Re: 97 Alt Bracket on my 1999 GTP?
    hangover park IL
    Quote Originally Posted by 97AutoXVette View Post
    He's referring to the f body 99 bracket.
    the later f-body brackets...late 98 and 99 is the one that is horizontal bolts for the old larger alternators as well as having both elbows replaceable... ie the elbow is not integral like the earlier W body front wheel drive bracket
    ~James~ Psychotic Gearhead
  12. #32 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    curious if I need to remove the coolant spare reservoir to remove that bracket? hoping to install the rockers tomorrow
    2002 GTP sedan:
  13. #33 Re: 97 Alt Bracket on my 1999 GTP?
    redneck tennessee
    Yep,I believe so. Hell, I find it hard to remove the accessory belt with it on.lol.
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. N * Bracket
    By Makdaddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 09:13 PM
