Thread: 2005 gtp voltage fluctuating
Results 1 to 6 of 6
  1. #1 2005 gtp voltage fluctuating
    Jun 2013
    Hollywood ,FL
    Whats up I been monitoring my voltage and at times its at 14.6 which is great but other times maybe at low 13s or high 12s even with ac and headlights once it hits 12.7 it like to charge I obviously cant have this because my voltage to fuel pump drops about .5 vdc from the battery to fp my question is is my alternator going bad or regulator in it and also is there a votage booster for the 2005+ years ?
  2. #2 Re: 2005 gtp voltage fluctuating
    Jun 2013
    Hollywood ,FL
    Bump
  3. #3 Re: 2005 gtp voltage fluctuating
    Buffalo
    http://www.grandprixforums.net/threa...ternator/page2
    does not really confirm nor deny anything actually - lol I can see why it's frustrating using the "search" sometimes
  4. #4 Re: 2005 gtp voltage fluctuating
    Jun 2013
    Hollywood ,FL
    Maybe faulty alt not sure going to try big three tomorrow
  5. #5 Re: 2005 gtp voltage fluctuating
    Buffalo
    The big 3 doesn't fix any problems.... If you are experiencing a voltage issue on a stock set up, I would have the alternator tested for free at an auto parts store.
    Upgrading your ground wire and power wire with a good working electrical system is always nice to have. It helped me carry the amperage I was demanding from the power system when using aftermarket stereo equipment.
  6. #6 Re: 2005 gtp voltage fluctuating
    Jun 2013
    Hollywood ,FL
    Yea ill have them check it out definately could it be the battery maybe?
  1. Rpm's fluctuating between 3rd and overdrive
    By lamonicas in forum General Grand Prix Discussion
    Last Post: 11-21-2013, 09:38 PM
  2. Fluctuating RPM's!!
    By Bessesen2 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 06:50 AM
  3. xp cam fluctuating rpm
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2011, 12:14 AM
  4. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  5. Badly Fluctuating RPM's
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 08:07 AM
