Thread: Dyno Numbers for the Turbo 04!
Results 1 to 20 of 25
ADrugDealer Dyno Numbers for the Turbo 04! 08-10-2014, 08:28 PM
16MustangVet Re: Dyno Numbers for the... 08-10-2014, 09:00 PM
ILoveAudi Re: Dyno Numbers for the... 08-10-2014, 09:03 PM
ADrugDealer Re: Dyno Numbers for the... 08-10-2014, 09:11 PM
blownGP Re: Dyno Numbers for the... 08-10-2014, 09:15 PM
wa04compg Re: Dyno Numbers for the... 08-10-2014, 10:49 PM
TwinV6GTP Re: Dyno Numbers for the... 08-10-2014, 11:51 PM
Turbocharged400sbc Re: Dyno Numbers for the... 08-11-2014, 06:48 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 08:41 AM
SnowFlake Re: Dyno Numbers for the... 08-11-2014, 09:06 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 09:11 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 09:14 AM
SnowFlake Re: Dyno Numbers for the... 08-11-2014, 09:46 AM
16MustangVet Re: Dyno Numbers for the... 08-11-2014, 09:48 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 09:53 AM
16MustangVet Re: Dyno Numbers for the... 08-11-2014, 09:57 AM
SnowFlake Re: Dyno Numbers for the... 08-11-2014, 10:01 AM
SnowFlake Re: Dyno Numbers for the... 08-11-2014, 10:07 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 10:11 AM
SnowFlake Re: Dyno Numbers for the... 08-11-2014, 10:12 AM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 10:16 AM
TwinV6GTP Re: Dyno Numbers for the... 08-11-2014, 10:04 PM
ADrugDealer Re: Dyno Numbers for the... 08-11-2014, 10:15 AM
GTPpower Re: Dyno Numbers for the... 08-13-2014, 09:35 AM
87IROCZOWNER69 Re: Dyno Numbers for the... 08-17-2014, 10:47 AM
  1. #1 Re: Dyno Numbers for the Turbo 04!
    Oct 2011
    Puyallup WA
    Very cool man! I need to finish buying parts for my turbo build
    08 G8 GT - exhaust Tune
  2. #2 Re: Dyno Numbers for the Turbo 04!
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Turbo 3.8 make ridiculous amount of torque. What saves us usually is lack of traction.
    This is why I can do 2nd gear starts and still do a 1.6 60 foot. With a 2.6 pulley on the S/C before there was no way in hell I was doing a 2nd gear start and have a good ET.
    I too had luck with stock trans in a FWD application. but if you hook hard, you will break it sooner than later with that amount of torque. That is pretty impressive for 3700rpm pull.
    That said the best thing we turbo guys can do is buy a smart RPM based boost controller which would limit torque at low RPM.
    Most cars running high boost have to do that either for traction or to protect the transmission.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  1. Low dyno numbers?
    By gtpguy98 in forum General Tech Discussion
    Last Post: 02-11-2014, 03:19 PM
  2. New Dyno Numbers
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 05-14-2012, 06:38 PM
  3. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  4. Ok here is my dyno. Why aren't these the numbers I should be getting?
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 10:14 AM
  5. Pacesetter header dyno numbers?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2008, 09:23 AM
