Thread: Im Lost...ABS/TCS Light Issues...
Results 1 to 19 of 19
  1. #1 Im Lost...ABS/TCS Light Issues...
    GT Level Member 05CompG's Avatar
    Arizona
    Ok so for the past couple months, ive had these stupid lights on (ABS, TCS, Stability System, Service Brake System) And based on my readings here, i concluded that it was a wheel hub issue...so i went about replacing them. Back two were replaced at different intervals (like a week or so apart), lights still were on. Then this weekend i finally get to replacing the front two...lights still on. FML....then i search the site again, found out about possible broken connections. So i look for those. No Luck...all connections are fine EXCEPT driver rear. its not broken but it does have a nick in the line. So if this is the cause of the lights, what is the proper fix?
    Her Name...Stacii Dash
  2. #2 Im Lost...ABS/TCS Light Issues...
    Could be.. Either way that should be addressed.. Cut the line.. Pull back the insulation till it's clean wire then solder and throw some heat shrink tubing over it..
    Unless you want to pay a shop to scan it for you this is a potential cheap fix!
    04 Comp G.
  3. #3 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    Pics of said connecter
  4. #4 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    Well thing is, after i got the hubs all replaced, and the lights were still on, i did end up taking it to a shop and having the ABS system scanned and the tech told me it wasnt throwing any codes...which is why im lost lol...idk wtf to do.
  5. #5 Re: Im Lost...ABS/TCS Light Issues...
    http://www.grandprixforums.net/threa...lems-Go-Figure
    Try ^ that sometimes it works sometimes it doesn't but it's something you can do that won't cost you anything unless you don't have a multimeter. It can help pinpoint the problem area and give you a direction as to which sensor/wiring could be the culprit.
    Oh and fix that wire too it's asking for a weak connection and for corrosion to get into.
    04 Comp G.
  6. #6 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    I think im going to end up ordering a whole new rear harness. Hopefully that does solve the issue. I tried that multimeter thing (That specific thread actually)...maybe im just dumb but i couldnt figure it out...lol i didnt know what to put the multimeter on, i tried it on all the settings and wasnt getting anywhere so...yeah...lol
    But here is the P/N for a new harness in case anyone else maybe having this issue...its only 58 bucks + shipping.
    http://www.gmpartsgiant.com/parts-li...anti-lock.html
    P/N: 15776487 (#1 in the pic)
    (Pic and Part # ctsy of BlackArrow98GP Over on GPONA.com)
  7. #7 Im Lost...ABS/TCS Light Issues...
    Noted lol. Oh and try RA might be able to get it cheaper.
    Will bookmark that so when I get around to fixing my abs light again I have a good harness to throw on there.
    04 Comp G.
  8. #8 Re: Im Lost...ABS/TCS Light Issues...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I need to get pictures or videos explaining how I tested the wire or just a simple diagram would work. Its hard to explain kinda if you have never done it before.
    Take that part # to the dealership they might be able to get it cheaper than GMPD or online GM dealer store thingys.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    Well honestly, i understood the testing the wire at the EBCM part....my issue was testing it at the hub as well as what settings the multimeter needed to be on...all those numbers and diff settings for OHM and DC and all that crap confused the hell out of me. But im gonna try the dealer and see. Hopefully i can get it a lil cheaper. If not, 65 bucks shipped isnt that bad for a peace of mind...lol this s**t is irritating.
  10. #10 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    RA actually has it as more...$81 before shipping. I was kinda shocked when i saw that. They usually are the cheapest.
  11. #11 Im Lost...ABS/TCS Light Issues...
    $56 on eBay
    Edit: item # 231268534851
    04 Comp G.
  12. #12 Re: Im Lost...ABS/TCS Light Issues...
    Apr 2012
    Dayton, OH
    I set my DMM to measure like 5000ohms, or whatever number is closer to 1000 without going under 1000.
    2012 F150 STX
  13. #13 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    So it needs to be on the ohms side on the clostest to 1k without going under...at that point, when i touch one prong to pin 2 and the other to pin 3, what should happen? and while im testing each pin, should the key be on or off?
  14. #14 Re: Im Lost...ABS/TCS Light Issues...
    Apr 2012
    Dayton, OH
    Car need to be off and yeah set it closest to 1k without going under I forget what the increments are mine has, so yeah to check 1 bearing from the EBTCM connector put the leads on the pins corresponding to the bearing you want and it should have somewhere around 1070ish Ohms or at least mine did. Then its the same for the pigtail at the hub should read about 1070ish ohmns, its just harder to get a solid connection. If it reads 0 at the connector but at the hub it reads fine a wire is probably broke someplace.
    2012 F150 STX
  15. #15 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    So another question, if im testing at the hub, should the underhood connector be plugged in? and vice versa for if im under the hood?
  16. #16 Re: Im Lost...ABS/TCS Light Issues...
    Apr 2012
    Dayton, OH
    If your testing the hubs pigtail it can be unplugged because you gotta unplug it by the HUB to test it anyway. If your tested using the under hood connector make sure the hub is plugged into the main harness.
    2012 F150 STX
  17. #17 Re: Im Lost...ABS/TCS Light Issues...
    Arizona
    Ok. Ill try all of the testing again sometime this week. Maybe it can confirm what i already know. Hopefully its just that harness. If not, im driving it off a cliff.
  18. #18 Re: Im Lost...ABS/TCS Light Issues...
    Apr 2012
    Dayton, OH
    Just pull the bulb from the cluster and DIC lol, losing TC and ABS and magnasteer isn't a huge loss in my book.
    I just hope I'm not confusing you, I hate wasting someone elses time.
    2012 F150 STX
  19. #19 Re: Im Lost...ABS/TCS Light Issues...
    Akron, Ohio
    clip the wires where they are cut and put on a new end. Cost maybe $10 and takes a couple minutes.
  1. HUD issues/oil pressure light on
    By chatbreaker in forum General Grand Prix Discussion
    Last Post: 03-31-2014, 07:11 AM
  2. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  3. Having LED reverse light issues.
    By Jtiger360 in forum Visual/Body Modifications
    Last Post: 01-07-2013, 09:56 PM
  4. Fog light issues
    By Fiero in forum 04+ Specifics
    Last Post: 03-17-2012, 11:26 PM
  5. Dome light issues, help
    By cojo in forum General Tech Discussion
    Last Post: 04-13-2011, 06:21 AM
