Thread: Does the rear o2 sensor need to be a certain distance from the catalytic converter?
Results 1 to 4 of 4
  1. #1 Does the rear o2 sensor need to be a certain distance from the catalytic converter?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Just wondering if it has to be a certain distance or if i can make the sensor closer to the converter.
    Thanks,
    chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Does the rear o2 sensor need to be a certain distance from the catalytic converte
    Within a few inches is just fine.
  3. #3 Re: Does the rear o2 sensor need to be a certain distance from the catalytic converte
    Jun 2012
    Illinois
    alright thanks, so if i move it closer to the cat ill be okay? any downsides of moving it closer?
  4. #4 Re: Does the rear o2 sensor need to be a certain distance from the catalytic converte
    Well if you have it right on the ass end of the cat it might melt it from the heat inside the converter.
    Thats why within a few inches is fine, 5in give or take.
  1. catalytic converter
    By musicman126 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2013, 12:09 PM
  2. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  3. sensor after catalytic converter
    By jerrysalley in forum General Tech Discussion
    Last Post: 01-05-2011, 09:36 PM
  4. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
