Thread: Trac and ABS dont work!?!?
Results 1 to 4 of 4
  1. #1 Re: Trac and ABS dont work!?!?
    PA
    Quote Originally Posted by 99gpse View Post
    yesterday morning i had to jump my Legend due to the cold weather and a dead bettery. i went to move the GP, and it must be said, it is VERY slick and snowy out. when i went to pull forward i could feel the wheels slipping and the spedo went up a little. i waited for the trac to kick in and pull me forward, but it didnt come on. finally got moving and when i went to stop. there was no feedback from the brake pedal, and the wheels locked up and the car started to slide sideways. i was only going maybe 5mph when i hit the brakes, but the ABS still should have kicked in! after starting the Legend, i went to move the GP back and the trac came on this time, also when i went to pull around the side of the building, the ABS came on.. also there where no warning lights, and the TRAC OFF light was not on. so what could this have been? it wasnt all that cold, maybe 20ยบ... so what could cause this?? any help?
    When you first start your car and put it in gear, your ABS does a "self test". It does a test to make sure everything is working correctly. On some cars you can hear and feel the car do this. It makes a groaning/grinding noise much like your ABS feels like when it kicks in. This is the self test. I know if I start my car, put it in gear and start moving too quickly before the test completes, it will disable my ABS and throw on the ABS and trac off lights. If I stop, turn the car off, restart it and start moving slowly, I don't have an issue. Maybe it is just a thing with my car being older, I don't know.
    But my guess is that you started moving the car too quickly by spinning the wheels and the system didn't have a chance to complete the test. Try starting the car, letting it idle, putting it in park, keep your foot on the brake, and start moving slowly. If that doesn't work, disconnect your battery for a couple minutes and try again. If that still doesn't work, you may need to replace a wheel bearing as I would think you have a bad wheel speed sensor. But that is last resort. Do what I suggested first.
    2001 GSE
  2. #2 Re: Trac and ABS dont work!?!?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Zef_66 View Post
    is it necessary to replace the whole bearing on these cars, and not just the sensor itself?
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  3. abs and trac off light staying on
    By gtpinsc in forum General Tech Discussion
    Last Post: 08-20-2008, 07:34 AM
  4. Trac Off Issue
    By catcamvegas in forum General Tech Discussion
    Last Post: 07-25-2008, 10:01 AM
  5. Gr-2 or Sensa-Trac not a GP
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2008, 07:16 PM
