Thread: Car is vibrating
Results 1 to 20 of 23
  1. #1 Car is vibrating
    Apr 2012
    North Dakota
    I need help bad. I replaced on the drivers side the wheel bearing and tie rod all motor mounts were changed to poly in the last month. The car still vibrates under acceleration only at 50+ mph. When not under throttle it is completely smooth. Under throttle it shakes pretty bad. I think it is a different problem but if I go around a corner and give it a little gas I can hear a loud rattling in the rear of the car. Please help me figure what is causing this. I am sick of replacing parts that don't need to be fixed.
  2. #2 Re: Car is vibrating
    blown axle.
  3. #3 Re: Car is vibrating
    Apr 2012
    North Dakota
    for sure? also what would cause almost a hollow knocking in the rear while under acceleration.
  4. #4 Re: Car is vibrating
    the exhaust bouncing around maybe?
    if its smooth at speed off the gas, then vibrates when on the gas the side you feel shaking has the bad axle.
  5. #5 Re: Car is vibrating
    CV axle.
  6. #6 Re: Car is vibrating
    Enfield, CT
    Definitely an axle. Wife had the same issue and a new axle is the fix.
  7. #7 Re: Car is vibrating
    Apr 2012
    North Dakota
    are there some things i should replace while im in there? as i do believe the wheel bearing is just beginning to go out as well.
  8. #8 Re: Car is vibrating
    not really, unless you want to lca's and sway bar bushing and end links.
    at least you dont have to take the brakes off this time round lol
  9. #9 Re: Car is vibrating
    Apr 2012
    North Dakota
    hit and a miss guys replaced the passenger wheel bearing and cv axle. It did help a little but still vibrates is it a strut? i honestly have replaced anything i can logically think of that would make the car vibrate like this. it does also vibrate more when i hit a large bump or a low spot in the road.
  10. #10 Re: Car is vibrating
    Enfield, CT
    That's weird. Did you torque the wheels to 100 ft lbs? How are the LCAs, inner & outer tie rods? Bent rim? Belt shift in the tire? maybe a wheel weight flew off
  11. #11 Re: Car is vibrating
    You could just wait til the vibrator your date dropped in the car runs out of batteries.
  12. #12 Re: Car is vibrating
    Enfield, CT
    Funny as fvck. I'm gonna catch **** for this because this response is so late but I've been real busy so sue me.
  13. #13 Re: Car is vibrating
    Apr 2012
    North Dakota
    Quote Originally Posted by highoctaneracing View Post
    what do I check on LCA's, will look at the wheel weight but doubt it and what do I look for on inner and outer tie rods? no way it has a bent rim and it slowly got worse and how do I know if the belt shifted?
  14. #14 Re: Car is vibrating
    Enfield, CT
    Look for worn bushings on the LCA and check balljoint. Jack up car safely and grab both inner tie rods and shake side to side to see if there is any play. Same with outer tie rods. Look at the tire to see if it is out of roundness to check for belt shift. easiest way is to dismount tire but you need a tire machine. youtube has videos
  15. #15 Re: Car is vibrating
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Here are the LCAs on my moms car, I would say these are bad. So I would look for possibly something like this. Mine looked similar before I replaced them. For shifted broken belts, on my car I pulled the wheels off and looked on them for any deformations and rolled them slowly and you could see the tread not flat it was raised up in some spots it also wobbled really bad.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  16. #16 Re: Car is vibrating
    Apr 2012
    North Dakota
    nope they don't look anything close to that. So what would cause this only under acceleration... it makes no sense to me and i will be doing the coil packs, wires, and plugs so hopefully that fixes any other ideas guys and it feels like it mostly comes from the passenger front side. Anyone else got an idea?....
  17. #17 Re: Car is vibrating
    Apr 2012
    Dayton, OH
    Under acceleration is usually the axles
    2012 F150 STX
  18. #18 Re: Car is vibrating
    Apr 2012
    North Dakota
    replaced the passenger side and the left side feels smooth when driving seems like the vibration is coming from the right...
  19. #19 Re: Car is vibrating
    when does it vibrate? on or off the gas or both?
    does it get worse when you hit the brakes?
  20. #20 Re: Car is vibrating
    try rotating that tire yet to the back?
  1. Grinding/Humming/Vibrating...
    By Brammer in forum General Tech Discussion
    Last Post: 10-21-2013, 07:10 PM
  2. a/c fan vibrating?
    By WOTFTW in forum General Tech Discussion
    Last Post: 06-18-2012, 09:42 PM
  3. Wierd vibrating noise
    By Tkuligowski in forum 04+ Specifics
    Last Post: 03-08-2012, 07:03 AM
  4. Vibrating issues
    By Piggy in forum General Tech Discussion
    Last Post: 01-31-2010, 12:44 AM
  5. Car Vibrating badly
    By bcrosby51 in forum General Tech Discussion
    Last Post: 07-23-2008, 07:52 AM
