Depends on what you're doing. If you're MAF or VE tuning you want to disable your PE and hit as many RPM and throttle combinations as possible. You should probably read through Jerry's guide on how to get a good scan, follow that step by step, and then use Eddie's SDT to use the scan and modify your calibrations. Jerry's guide goes over all of that start to finish.
