Thread: Which MAF sensor is this?
Results 1 to 3 of 3
Impala131 Which MAF sensor is this? 07-11-2014, 02:13 PM
Impala131 Re: Which MAF sensor is this? 07-12-2014, 01:53 PM
Slick2500 Re: Which MAF sensor is this? 07-13-2014, 12:02 AM
  1. #1 Which MAF sensor is this?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hey all,
    I pulled this MAF sensor off of a 2001 Cadillac Deville (4.6L Northstar) . Looks like an LQ4 MAF from the photos I have seen, but I've been told that this model did not use the LQ4 MAF.
    http://s1265.photobucket.com/user/gtp131/library/MAF
    The number molded into the plastic reads 25168491.
    The printed number above the bar code is 25168491.
    The printed number below the bar code is 0213881A.
    Thanks
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Which MAF sensor is this?
    Knoxville, TN
    Based on web searches and reading, this is the same MAF as an LS1 uses. So perhaps I need to start with an LS1 MAF table for tuning and adjust from there?
  3. #3 Re: Which MAF sensor is this?
    I found this http://fndpartsco.com/?product=2005-...r-25168491-oem looks to be a factory N* maf.
    -Edit- it looks like they used that same maf on a ton of vehicles. This part is compatible with 721 vehicle(s)
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
