Thread: downpipe hitting tunnel - any thoughts?
Results 1 to 7 of 7
  1. #1 downpipe hitting tunnel - any thoughts?
    Ocala, FL
    So, I installed headers about 7-8 months ago. My car is lowered, so I had spacers to raise the engine to reduce vibrations. With the headers installed, the downpipe contacted the tunnel/firewall, so I removed the spacers, and all seemed OK.
    Noticed after a few months I was getting a slight power steering leak from under the car. Power washed the engine, and saw the leak was coming from a power steering line, right next to the downpipe. The downpipe had burned/sawed a hole through a power steering line.
    I replaced the power steering line(which was a pain!), and zip tied them down a bit out of the way, but the downpipe could still make a tiny bit of contact. I figured the reason the downpipe was making contact was due to worn engine mounts, so I replaced both lower engine/trans mounts with poly mounts. The stock mounts were smashed flat. Now the engine is back up off of the power steering lines, but is now hitting the tunnel/firewall again.
    Any thoughts on how to resolve this?
  2. #2 Re: downpipe hitting tunnel - any thoughts?
    Oct 2011
    Toledo, OH
    How low are you? My SD's fit too perfect, so that when I put my spacers in I'm afraid of exactly what you're saying. My power steering hard line actually rests against the rear header too.
    7"
  3. #3 Re: downpipe hitting tunnel - any thoughts?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    BFH+ floorboards= header clearance
  4. #4 Re: downpipe hitting tunnel - any thoughts?
    Ocala, FL
    Quote Originally Posted by industrialfish View Post
    Yeah, I thought mine was just resting on there, until it started leaking.
    I'm lowered on agx struts, with ssc springs. Probably dropped about 1.5 inches.
    Quote Originally Posted by danomite02 View Post
    I figured this might be about my only option.
    I wish I had a lift, would give me a lot more clearance to do it.
    I installed my catback on my back with my car on four jackstands.
  5. #5 Re: downpipe hitting tunnel - any thoughts?
    Dec 2012
    troll land
    Lemme gues, you have zzps "shortened" dbs
  6. #6 Re: downpipe hitting tunnel - any thoughts?
    May 2012
    Where winter never ends
    Its hammer time!
    I beat mine with a hammer and we were all good!
    2000 Regal - Winter Beater
  7. #7 Re: downpipe hitting tunnel - any thoughts?
    Ocala, FL
    Quote Originally Posted by l67ss View Post
    Nope, if I did my problem would be far worse.
  1. sub not hitting as hard as it used to
    By jjmitch87 in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2013, 12:20 PM
  2. Lock it up
    By PurpleGuy in forum For Sale - Parts
    Last Post: 09-26-2013, 03:42 PM
  3. The all to common DP hitting the Swaybar
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 03-02-2013, 02:17 AM
  4. Door hitting fender
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 09-19-2012, 11:36 PM
  5. door hitting fender
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 11-30-2010, 08:11 PM
