Thread: Turn signal trouble
Results 1 to 4 of 4
  1. #1 Turn signal trouble
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Ok so my driver side turn signal blinks a lot faster as if a bulb were burnt out but all the bulbs are fine and I have led tail lights. I have hid's in my head lights and fog lights and I found out the turn signal blinks at normal speed when all lights are off and faster with fog lights on and then really fast like a bulb is out if both my fog lights and head lights are on. This only affects my driver side. Any ideas on what could cause this? Thanks
    Thanks,
    Points70
  2. #2 Re: Turn signal trouble
    take the led lights out and put the stock bulbs back in, see if it stops doing it.
  3. #3 Re: Turn signal trouble
    Nov 2010
    I'll try that but does it matter that it has just started doing this and it's been a year with it all in?
    Thanks,
    Points70
  4. #4 Re: Turn signal trouble
    led's are know for the double speed flash deal, maybe one of the resistors burned out.
    then there's checking all your grounds and making sure all the bulb sockets are clean, and that all the bulbs are working. check all the wires for damage too.
    change the bulbs from one side to the other, see if it follows.
    i do hate electrical issues.
  1. Turn Signal not working
    By FX4 Level II in forum General Tech Discussion
    Last Post: 03-19-2012, 08:04 AM
  2. Turn signal
    By penguinknot in forum General Tech Discussion
    Last Post: 09-11-2011, 04:46 PM
  3. turn signal help
    By sUpErClEaNbLaCkMaChInE in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2011, 08:09 PM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
