Thread: DIC Tranny Temp Reading
Results 1 to 8 of 8
  1. #1 DIC Tranny Temp Reading
    Aug 2012
    DC
    In a few other threads I mentioned how my DIC Tranny Temp was registering over 250 degrees when driving for long periods on the highway!
    I took it to my mechanic to put a tranny cooler on it and he did some driving to observe the temp reading. The fluid looked great and he thought it was unusual how fast the temp seemed to rise.
    When he got back to the garage he put a thermal gun on the tranny hose to see what reading came up - the reading was 159 degrees but the DIC said 201.
    After the car cooled down his thermal reading and the DIC were about 5 degrees off which could be normal, but the 'hotter' the DIC got the bigger the disconnect with the thermal reading.
    The engine never got hot and the fans only kicked in once during his test which cooled things off 15 degrees before turning off so all those temps seem normal.
    He went ahead with the tranny cooler as cheap insurance but has anyone seen this kind of disconnect with the DIC reading?
  2. #2 Re: DIC Tranny Temp Reading
    Taking a reading off the hose might not be the best. The fluid temp inside the hose could be much cooler.
  3. #3 Re: DIC Tranny Temp Reading
    Feb 2010
    TN
    The DIC lists tranny temp? I have a 97 and never noticed it how do I get to it?
  4. #4 Re: DIC Tranny Temp Reading
    Aug 2011
    'Merica
    04+ only as far as I know
  5. #5 Re: DIC Tranny Temp Reading
    Oct 2011
    Toledo, OH
    250 sounds pretty high. Get a scan gauge of some kind. My AutoTap will show trans temps and it's only a couple degrees off, small enough that I trust the DIC reading.
    7"
  6. #6 Re: DIC Tranny Temp Reading
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by goochman View Post
    Not to knock your mechanic, but a thermal gun is not a helpful tool in this scenario. Unless this is a special thermal gun that I'm unaware of, it only takes the surface temperature of a material. A tranny hose (assuming rubber) would not transfer the fluid heat to the outside of the hose very well at all. Even trying to take a reading off of metal object will not give you an accurate fluid temperature.
    Do you have the tranny cooler connected to the radiator? If so, you'll stay fairly close to your engine temperature anyway. The radiator will heat or cool the fluid closer to your engine coolant temperature.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: DIC Tranny Temp Reading
    Aug 2012
    DC
    After the tranny cooler was installed the temp is not progressing above 205 on the DIC. My mechanic figured the thermal gun wouldnt be exact but thought it should be close enough.
    Anyhow - I think IM good for the long run, just wanted some thoughts on whether or not anyone has seen a DIC Tranny temp not be correct but seems like it most likely was.
  8. #8 Re: DIC Tranny Temp Reading
    Aug 2012
    DC
    Oh I did a fluid change as well with the cooler install just to be safe - but the previous fluid looked pretty in pink
  1. Dual Climate Digital Temp Reading
    By danielle15 in forum General Tech Discussion
    Last Post: 05-31-2011, 02:46 PM
  2. Temp gauge is reading incorrect?!
    By hazards280 in forum 5.3L V8 (LS4)
    Last Post: 05-16-2011, 08:51 PM
  3. Temp Gauge Not Reading RIght
    By 2000 Grand Prix GT Blue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2010, 12:08 PM
  4. Temp Reading
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 09:30 AM
  5. Mirror Temp reading SC
    By Hamm61 in forum Audio, Security & Visual Electronics
    Last Post: 05-18-2009, 08:42 PM
