Thread: Temp gauge is reading incorrect?!
Results 1 to 5 of 5
  1. #1 Temp gauge is reading incorrect?!
    Midland MI
    I own a 2005 Grand Prix GXP and the temperature gauge is always reading incorrectly. I have plugged a scanner into the car and it shows the cars coolant temp at ~195, which is the stock thermostat temp.
    What could be causing my temperature gauge to be reading very low.
    About 1/2 way to the middle? Any ideas?
  2. #2 Re: Temp gauge is reading incorrect?!
    The gauge is reading about 1/2 way? That should be right, unless it has numbers on it?
  3. #3 Re: Temp gauge is reading incorrect?!
    Midland MI
    It's half way to the half way point. That was worded poorly!
    1/4 of the way up the gauge.
  4. #4 Re: Temp gauge is reading incorrect?!
    SE Level Member Hoss Lanier's Avatar
    Apr 2011
    Calhoun, La.
    after my new water pump today, mine ran that same temp....
  5. #5 Re: Temp gauge is reading incorrect?!
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    The gauge in my 98 GrandPrix 3800 reads half of what it should also. I replaced the 3 wire coolant temp sender, and thermostat, with no change, except a $50 lighter wallet. My code reader shows that the ECU says the temp is normal operating temp also. I think there is an issue with the gauge cluster but I dont know. Maybe there is a resistor in line or something. Not a clue. I too would like to know what the issue is.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  1. Temp Gauge Not Reading RIght
    By 2000 Grand Prix GT Blue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2010, 12:08 PM
  2. Temp Reading
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 09:30 AM
  3. Factory Boost Gauge reading
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 02:50 PM
  4. Mirror Temp reading SC
    By Hamm61 in forum Audio, Security & Visual Electronics
    Last Post: 05-18-2009, 08:42 PM
