Thread: PLOG vs headers.
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41 Re: PLOG vs headers.
    id just stick with the SD's for the cost if nothing else.
    you dont have to do a thing to them, but most will change out the flex pipe to a better one. removing the that dumb drain trap in the dp is easy to get done too. you could make all your cuts with a sawsall and have it welded up.
  2. #42 Re: PLOG vs headers.
    GT Level Member kking89's Avatar
    st.louis
    Is the drain pipe worth getting rid of? Cause I'm trying to not have to do any or not very much fabrication
  3. #43 Re: PLOG vs headers.
    Aug 2013
    McDonald PA
    Quote Originally Posted by kking89 View Post
    Not really iirc
  4. #44 Re: PLOG vs headers.
    st.louis
    And supposedly the pacesetter from zzp. With the pro kit fixes all the issues.
  5. #45 Re: PLOG vs headers.
    like i said, you "dont need" to do anything to just run them. the flex will last long enough and the drain trap is just a bit low and could bottom out if lowered. stock cars dont seem to have a issue really.
  6. #46 Re: PLOG vs headers.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    But compare the cost of the two unless that has no factor in it
    2012 F150 STX
    - Gonna be a race truck
  7. #47 Re: PLOG vs headers.
    Aug 2013
    McDonald PA
    Just get SDs use Rtv and band clamps and replace the flex with a zzp flex and your golden. Easier install than pace****ters too a lot of people would never let them on their car. Smuts had zzp headers and hated them
  8. #48 Re: PLOG vs headers.
    st.louis
    I'm guessing the rtv and band clamps can be found at zzp. Or what about a cheaper supplier like rock auto?
  9. #49 Re: PLOG vs headers.
    Apr 2012
    Dayton, OH
    I would imagine any local auto parts store, they may have to order them depending on how many they stock.
    2012 F150 STX
  10. #50 Re: PLOG vs headers.
    Aug 2013
    McDonald PA
    Advanced auto has them order them online use a coupon code and then pick them
    Up in store saves money
  11. #51 Re: PLOG vs headers.
    parts store or frozen boost for the clamps. if you need a fake cat they sell them there too for 40 bucks.
    copper rtv.
    f zzpoopy lol
  12. #52 Re: PLOG vs headers.
    st.louis
    copper rtv.
    f zzpoopy lol
    I'm in Missouri so I think I need cat. Cut I'm pretty sure the emissions test it probed and not just all looks. So the rtv. Is a silicone sealer. And the band clamps are exactly what the name says haha. That double wall flex from zzp is cheap as well
  13. #53 Re: PLOG vs headers.
    this rtv
  14. #54 Re: PLOG vs headers.
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I think Im gonna grab that rtv and a new band clamp because I wrecked my band clamp trying to seal the front header to the crossover lol
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  15. #55 Re: PLOG vs headers.
    Nov 2012
    Erlanger, KY
    I use plogs on my turbo setup.. but for a SC setup, headers are just the way to go. With so many options out there now from cheap to expensive, no reason to not
    go that route.
    I am not a big fan of the band clamp setup.... didn't like em on SLP... didn't like em on ZZPs... never done the cheaper ebay ones but figure about the same.
    If i was to get some cheapies, i'd at least invest to get a vband setup on them instead....
    Still rocking TOGs for 10+ years on my daily turd.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  16. #56 Re: PLOG vs headers.
    Oct 2011
    Puyallup WA
    I guess I am part of the minority...I had a zzp dp and at a later date decided I wanted to do headers...never made much money back on DP because no one really wants them used...selling the plog shouldn't be a issue but I guess I don't understand why not running what you have so you can spend time and money on other stuff...SD headers do not just fly on the car not leak and have zero issues...guess for most people they want a specific whp so prob better listen to the pro's that have seen zero gains from Plog+DP...oh and the pro's will say xp cam only all day every day so better skip the VS lol
    08 G8 GT - exhaust Tune
  1. DP+Plog VS Headers
    By Fierogtfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2011, 11:32 PM
  2. plog>headers
    By wlmrt6 in forum Track Sessions and Kills
    Last Post: 07-15-2010, 02:09 PM
  3. PLog vs Headers
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 02:05 PM
  4. Headers or Plog?
    By 03buickregalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2009, 08:59 AM
