Thread: Fuel line fix
Results 1 to 7 of 7
  1. #1 Fuel line fix
    Feb 2010
    TN
    Truck blew a tire it went under car ripped fuel line out of fuel filter, tried the dorman fuel line repair kit, but og the ones they make one leaks like a sieve no matter how good I clamp it, the other will not even fit no matter how much hot water or heat you put on it. Any fixes besides go to boneyard drop a tank get a line come home drop my tank and swap? I really hate to drop two tanks
  2. #2 Re: Fuel line fix
    If you can get their metal barb on the tank side of the line.. then you could use fuel injection hose from there to the filter. ... Or run injection line from the top of the tank to the filter.
  3. #3 Re: Fuel line fix
    Feb 2010
    TN
    I cam't get that stupid barb in and I was thinking of injection line straight from the tank byt that seemed too easy figured I was missing something (also like have quick conntetors rathe than a clamp) but think thats the way I will go
  4. #4 Re: Fuel line fix
    The plastic line needs to be softened up with scalding hot water just stick the end in a bucket of hot water, then shove the doerman barb fitting on the line do the same with the other end. May need to buy 2 kits if you need fittings to put a section of line in to the fuel filter. Ive used them barb fittings before in the engine bay where the line meets up to the fuel rails. Scalding hot water is the key to getting them barbs to fit and not leak later down the road..
  5. #5 Re: Fuel line fix
    Feb 2010
    TN
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Been trying that by the time I get the pot from the kitchen acros the driveway it cooled off
  6. #6 Re: Fuel line fix
    GT Level Member mainecrab's Avatar
    Feb 2008
    I used the coupler here for something similar:
    http://www.autozone.com/autozone/acc...uestid=3251385
    The connection to the engine leaked so I had to get the Dorman part that had the connector then used that to join the old and new line. Reminds me of a water connection coupler.
  7. #7 Re: Fuel line fix
    Feb 2010
    TN
    Quote Originally Posted by mainecrab View Post
    hey that looks good
  1. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
