Thread: Help Identify A 10mm Bolt Missing Its Hole...
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Help Identify A 10mm Bolt Missing Its Hole...
    That really is very good.
    One of the flip cars we did.. the heads and every other part was in the trunk. Little boxes and you name it. We dropped a fresh motor in, but some stuff is different/missing. I dumped it all in a pile on the floor (whole garage bay) and picked what I needed. Went well overall.
  2. #22 Re: Help Identify A 10mm Bolt Missing Its Hole...
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Turns out that was exactly what happened, the 2 bolts that hold the EGR to the block are the exact same thread as the ISS bolt and a little less than a 1/4" shorter than the ISS bolt. I found the other one that goes to the EGR under a pile of discarded and broken parts. So problem solved. Thanks again guys!
  3. #23 Re: Help Identify A 10mm Bolt Missing Its Hole...
    Wow.. 5 guys over a couple weeks and ... one bolt off. That's really really good.
  4. #24 Re: Help Identify A 10mm Bolt Missing Its Hole...
    Feb 2010
    TN
    Logan... You never saw the threads I put up when I got bored? Stump BillBoost, literally asked people to post bolts and I'd tell them where they went. It's something you do after...you've worked on a platform too much.
    I finally got my head off the motor/trans and thought about how someone may have done this differently that I would.
    If that's the bolt I believe it to be.. he left the rack on the subframe when he lowered it.
    I do remeber that and I must say it was fun, interesting and at times amazing
  1. Oil leak from lower timing cover bolt hole
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2013, 11:11 PM
  2. getting bolt with no head out of rear header join hole?
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2013, 08:57 PM
  3. HELP! Identify the missing piece.
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2010, 07:52 AM
  4. Magnecor R-100 10mm Race Ignition Wires
    By Scimmia in forum Group Buys
    Last Post: 08-04-2009, 10:22 AM
  5. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
