Thread: Gauge cluster+ wheel speed
Results 21 to 40 of 61
  1. #1 Re: Gauge cluster+ wheel speed
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    You need a 97 cluster
    no you don't I have a 03 SE cluster in my 97 the gas gauge has a problem because it connects all 4 of the sender poles as where 97 only connects 3.. it's a pain but it will use whatever cluster just use the back of your 97, swap the odometer and put the face plate back on
    Sent from my SGH-M919N using Tapatalk
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  2. #2 Re: Gauge cluster+ wheel speed
    Quote Originally Posted by KoldAsIce View Post
    Well I meant if he wanted everything to work correctly
  3. #3 Re: Gauge cluster+ wheel speed
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Damn 97s really are picky arnt they
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    Dude get a cluster then pull the face and swap the odometer done.. mileage is correct
  5. #5 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    ^^^ Bill is very knowledgeable I'd trust his opinion
  6. #6 Re: Gauge cluster+ wheel speed
    Kold.. go back a page, I explained what was causing the issue... Post #12
  7. #7 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    Haha man he'd have to have one of those in order for that to be the reason.. Palmela doesn't bleed lol
  8. #8 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I dont know which ground to look for. It is an ignition issue. You can feel it in the car. Its not the cluster
  9. #9 Re: Gauge cluster+ wheel speed
    Smdh
    04 Comp G.
  10. #10 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Its been pissing me off really.
  11. #11 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I have checked grounds. Checked vacuum lines. Checked spark plug wires.
  12. #12 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    And it's just the rpms right? If it's revving a little different I'd say maybe something to do with the throttle body.. carbon build up etc
  13. #13 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    The mph seems to do it also
  14. #14 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    Well if your not having any issues ie revving, driving etc and it's just the cluster I'd have to assume it's either as Bill said a ground but I don't think one would just get messed up OR it's a sensor which can mess up randomly and seems to be more reasonable of a reason
  15. #15 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    It will you just have to fix more then just swapping it but I understand
  16. #16 Re: Gauge cluster+ wheel speed
    See Kold.. if we remember, Tim swapped his diff, then an engine, then the trans.
    Anyone who's swapped a motor, likely knows why I'm saying.. check your grounds.
  17. #17 Re: Gauge cluster+ wheel speed
    Mar 2013
    Staten Island, NY
    Ahhh this I did not no and yes makes very good sense now!
  18. #18 Re: Gauge cluster+ wheel speed
    It's like....if you swapped a motor and all of a sudden your traction/X and Y don't work.. you might have a ground issue.
  19. #19 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    My traction and all that was actually a wire ripped out of the abs connector lol
  20. #20 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I dont know exactly all the grounds to check are..
  1. Gauge cluster fix???
    By 92GPcoupe in forum General Tech Discussion
    Last Post: 02-28-2013, 06:02 PM
  2. Red Gauge Cluster
    By ShadowSwept in forum General Grand Prix Discussion
    Last Post: 09-09-2012, 04:04 PM
  3. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  4. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  5. Gauge Cluster
    By lstexan in forum General Tech Discussion
    Last Post: 04-23-2010, 11:13 AM
