Thread: 97-03 GTP stock valvespring lift rating?
Results 1 to 20 of 21
  1. #1 97-03 GTP stock valvespring lift rating?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Anyone know this? I believe stock lift is somewhere around .400" or slightly over that.
    Curious what lift numbers the stock springs are rated too.
    Thanks!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2012
    NC
    Just think stock...because you'll float valves anything higher than stock lift.
  3. #3 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2014
    Cincinnati, OH
    I guess I am more curious about coil binding at the moment.. I have a set of 1.9 ZZP modified rockers coming in soon, and am wondering whether or not to invest in springs. I am going to stay very close to stock shift points (right around 5500rpm is the plan). With so many people saying they have ran stock springs with these rockers, I was wondering if the stock springs were rated higher than the stock cam lift. I usually have not seen that being the case with the LS motors I used to work on.
    2002 GTP sedan:
  4. #4 97-03 GTP stock valvespring lift rating?
    I wouldn't chance it and would go ahead and change the springs especially since your stockers probably have some decent miles on them. Plus springs are rather cheap and easy to do so it's a no brainer.
    04 Comp G.
  5. #5 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2012
    NC
    Most people graduate to 90+lb springs with 1.9's...I imagine due to float issues. Although, I've already been proven wrong in a post earlier so don't listen to me. LOL
  6. #6 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2014
    Cincinnati, OH
    haha.. I did not see said post so I am all ears thus far. I am wondering if I would go 90 lbs or 105 lbs...
    2002 GTP sedan:
  7. #7 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2014
    Cincinnati, OH
    changing the springs without doing the timing chain and/or tensioner also makes me nervous though!
    2002 GTP sedan:
  8. #8 Re: 97-03 GTP stock valvespring lift rating?
    L76
    04 Comp G.
  9. #9 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2014
    Cincinnati, OH
    L76
    I'll have to check those out. What do they usually go for?? ($$)
    2002 GTP sedan:
  10. #10 97-03 GTP stock valvespring lift rating?
    Cheap!!!
    Last time I checked they were a few bucks each.. Most commonly out of the g8
    http://www.grandprixforums.net/threa...ngs-for-VS-Cam
    04 Comp G.
  11. #11 Re: 97-03 GTP stock valvespring lift rating?
    Mar 2014
    Cincinnati, OH
    Nice!
    I will check ZZP and a few other places and try and find a set. Maybe some are for sale on this forum now.. Will have to look
    2002 GTP sedan:
  12. #12 97-03 GTP stock valvespring lift rating?
    You won't find the L76 on ZZP but you can grab them from the dealership or gmpartsdirect etc etc hell probably even rockauto too
    04 Comp G.
  13. #13 Re: 97-03 GTP stock valvespring lift rating?
    Oct 2011
    Puyallup WA
    I ran stock springs for a couple years and had no issues shifting at 5950
    08 G8 GT - exhaust Tune
  14. #14 Re: 97-03 GTP stock valvespring lift rating?
    Quote Originally Posted by 97AutoXVette View Post
    My tensioner was cracking at ~88K miles. By that point, I had put maybe 5K on it with L76 springs and 1.9 rollers, the rest was stock. It's plastic. Always be afraid of old plastic, and any plastic you try and "force".
  15. #15 Re: 97-03 GTP stock valvespring lift rating?
    Oct 2011
    Puyallup WA
    Fwiw my tensioner had normal when I pulled it at 110k 15k or so had 1.9 rockers
  16. #16 Re: 97-03 GTP stock valvespring lift rating?
    Jul 2013
    adrian, mi
    Been running stock springs with Zzp 1.9s no issues. Shifting at 5700.
  17. #17 Re: 97-03 GTP stock valvespring lift rating?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Just run 105lb springs and the proper retainers and whatnot. No need to touch the timing chain if your engine has been well maintained. I put 105lb springs on a 170k block with no issues for the 10k miles I had them on.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  18. #18 Re: 97-03 GTP stock valvespring lift rating?
    Nov 2011
    NY
    I believe the stock cam lift is .278, when combined with the 1.9 gives you .528 lift. Stock V springs or the L76 V springs allow .520, so you should be using the modified retainers to avoid bind. If you're going this route, also figure to replace your valve stem seals as well.
    I used the L76 Spings with my rolling rockers as the sat pressure is pretty much the same as stock (90lbs) and therefore easy on valve train, tensioner,
    anyone can correct me if wrong, thanks : )
  19. #19 Re: 97-03 GTP stock valvespring lift rating?
    Oct 2011
    Puyallup WA
    Pretty sure 1.9 + stock cam is like .490 lift
  20. #20 Re: 97-03 GTP stock valvespring lift rating?
    Nov 2011
    NY
    Quote Originally Posted by wa04compg View Post
    lolz, corrected...
    Stock L67/L32: 182/192 .258/.258 115 N/A
    memory was off a bit, added .02, lol, sorry!
  1. EGR Valve Torque Rating
    By Bigheadedon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2013, 10:58 PM
  2. Torque rating for tie rod ends ?
    By GTP in RTP in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2012, 06:21 PM
  3. 1994 gtp octane rating?
    By rij1 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-16-2012, 08:49 PM
  4. Alternator Rating?
    By goodguy8705 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2009, 09:29 PM
  5. stock fuel injector rating?
    By elusive racing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 11:45 AM
