Thread: Changed Battery and now doesnt start right away
Results 1 to 12 of 12
  1. #1 Changed Battery and now doesnt start right away
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    Changed the battery in my 04 GP GT and went to start the car and it took longer to fire. Normally she fires up right away and now it takes a couple revolutions before it actually fires.
    does it need to relearn because of the battery replacement?
  2. #2 Re: Changed Battery and now doesnt start right away
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    How many times has that happened since you swapped the battery??
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: Changed Battery and now doesnt start right away
    Jun 2013
    London, Ontario
    i shut it off and started it probably like 3-4 times
  4. #4 Re: Changed Battery and now doesnt start right away
    Mar 2014
    Cincinnati, OH
    Unless you changed the battery to one with different rated cranking amps, I bet you're fine. I'd give it a few days and see how it's doing. I don't believe the computer learns much from a starting standpoint since that doesn't effect your fuel trims much.
    2002 GTP sedan:
  5. #5 Re: Changed Battery and now doesnt start right away
    Jun 2013
    London, Ontario
    ok, it cranks just fine. not sluggish at all.
  6. #6 Re: Changed Battery and now doesnt start right away
    Oct 2011
    Toledo, OH
    Check the amperage sensor (black round thing) on the ground wire at the battery.
    7"
  7. #7 Re: Changed Battery and now doesnt start right away
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    PCM just needs to re learn drive it for like 20min and it should be fine
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Changed Battery and now doesnt start right away
    SWPA
    Exactly what I am thinking. Everything will act slightly different at first, until everything gets learned in the ECU.
  9. #9 Re: Changed Battery and now doesnt start right away
    Jun 2013
    London, Ontario
    Seemed to start up ok this morning. Probably needed to re learn.
  10. #10 Re: Changed Battery and now doesnt start right away
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Could it have a been a "weak" new battery? There is a manufacturing date code on the side which is a small round sticker with a letter followed by a number. The letter stands for the month of mfg, A=Jan, B=Feb, the number is the last digit of year. A C4 sticker =March 2014. You may have bought a battery that was not fully charged and needed to be driven for a while to charge the battery.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  11. #11 Re: Changed Battery and now doesnt start right away
    mine will do this too if i take the battery out, will crank like 3 times then fire up vs a flick of the key normally. the pcm is just relearning.
  12. #12 Re: Changed Battery and now doesnt start right away
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    my 2000 SE 3.1 did the same thing when I put in a new battery
  1. Battery shut off, now radio doesnt turn on anymore
    By sLpGPGT in forum Audio, Security & Visual Electronics
    Last Post: 09-29-2013, 09:58 PM
  2. Car fires and turns over but doesnt start on the first try
    By Overboost101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 04:55 PM
  3. Changed my battery and now the car doesnt turn over as well.
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-26-2012, 01:21 PM
  4. Changed front rt control arm and now it wont start
    By AREED in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 09:31 PM
  5. 98 oldsmobile doesnt start!
    By fst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2008, 05:13 PM
