Thread: slow drivers side window
Results 1 to 5 of 5
  1. #1 slow drivers side window
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello, when i roll my driver side window up and down, it is much much slower then the other 3. it is even worse in the very cold weather, sometimes its not even able to roll itself all the way down. when it was warmer out i noticed that when i rolled it back up, most of the time, there was a vibrating sound and a small vibration in the door while it was going back up
    any thoughts?
  2. #2 Re: slow drivers side window
    GT Level Member nutcase's Avatar
    Washington State
    motor getting worn? had to replace both of mine because they got slow...i mean 1 minute slow! lol!
    My car doesn't leak oil,
    It marks it's territory.
  3. #3 Re: slow drivers side window
    Dec 2008
    Lincoln NE
    How do you replace the motor? Any special tools required to get the door panel off, etc.
  4. #4 Re: slow drivers side window
    Washington State
    Im not sure since my mechanic did it. check the regulators too. I think the motors get these dead spots in them....smacking your door sometimes kick starts it. I have replaced the whole window unit...even the buttons.
  5. #5 Re: slow drivers side window
    Charles City, IA
    Check the grounds. When they get corroded you motor will not be as fast. If those are not it I would go with the motor.
    SMGPFC Two Nipple General
  1. Carpet very wet on drivers side floor
    By magician1979 in forum General Tech Discussion
    Last Post: 10-26-2009, 03:18 PM
  2. UPDATE, pg.2!!! Drivers Door Adjustment? Hinge?
    By Iron Indian in forum General Tech Discussion
    Last Post: 12-30-2008, 12:52 PM
  3. upgrading to a HUD=$700 drivers windshield, WTF?!!
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-01-2008, 06:36 PM
