Thread: P0171
Results 1 to 14 of 14
  1. #1 P0171
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I keep getting this code. Could it be my O2 sensor? Car drives normal.
    Sent from my PantechP8010 using Tapatalk
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: P0171
    Thats a vacuum leak code.
    I'd try and find the leak with a smoke machine. Or switch back to a stock throttle body and maf data.
  3. #3 Re: P0171
    St. Louis
    Usually this is a vacuum leak somewhere. I've been fighting this code for a while now too, and my car drives fine as well. Replaced my upstream 02 (was old as whatnot, so figured it was time anyways), and still have the code. No vac leaks that I can find. I've even pulled the EGR tube and found it to be airtight, and sealed both ends. I think I'm about to have it smoked to see if I have a leak somewhere that I can't find. Tired of the damn CEL.
  4. #4 Re: P0171
    Apr 2013
    Milwaukee
    Ya, it's been coming on and off for awhile and actually when it came on today, I just did the egr block off with a dime and quarter and the quarter moved so I just put the egr valve back on. Possibly I didn't tighten it enough? I cleared the code, drove for a good 20 miles today and it came back on so I'll probably have to just try to tighten it down real good. Also my boost gauge reads normal vacuum as well.
  5. #5 Re: P0171
    I have also seen corroded battery cables cause this issue.
    This should not be an O2 sensor.
  6. #6 Re: P0171
    Apr 2013
    Milwaukee
    Well I tightend my egr stuff and double checked my vac lines and they seem good. So like Fordman, I will probably have to get a smoke test done cuz everything looks good and tight. Hope it's not my LIM gasket :/
  7. #7 Re: P0171
    Apr 2013
    Milwaukee
    BTW, I smoke cigs so could I actually do my own smoke test by blowing my cig smoke through a line? Also what line would be best?
  8. #8 Re: P0171
    Have you checked your 15 year old car for corroded battery cables?
  9. #9 Re: P0171
    Jul 2010
    Coquitlam,BC,Canada
    Pretty sure I had this code after working in the car a few years back. I had the MAF unplugged during the work. After getting the code, I unplugged the MAF, re-plugged it, and the code was gone.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: P0171
    Apr 2014
    CT
    Dont forget an exhaust leak before o2 can cause the code too.
  11. #11 Re: P0171
    Apr 2013
    Milwaukee
    I think I figured it out. I'm pretty sure it was my egr tube to the intake that was bent up a little. I deleted my egr today and so far the code hasn't come back after a good 30 mile drive.
  12. #12 Re: P0171
    The code takes two tests to set the light. Go drive more.
  13. #13 Re: P0171
    Apr 2013
    Milwaukee
    I think it's good. I'll have to keep an eye on it.
  14. #14 Re: P0171
    SE Level Member DCGTP's Avatar
    Charleston SC
    I had this code a while but after a good MAF cleaning I haven't seen it once...
    Overkilled, AL605s, 180 T-stat, Cone Intake, Cross drilled & Slotted Rotors, f-body upgrade, poly upper mounts, shorter dog bones,
    factory nav, 2x12s in the trunk, interior LED swap, all 5000k HIDs, red halo's in upper grille, tinted tails and reverse lights, de-badged, XM to line in conversion
  1. Chasing a p0171
    By hensleya1 in forum General Grand Prix Discussion
    Last Post: 06-24-2013, 04:40 PM
  2. p0171 help
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2013, 11:42 AM
  3. P0171 help please
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 02:21 AM
  4. p0171 help
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2012, 08:07 AM
  5. p0171
    By sca555 in forum General Tech Discussion
    Last Post: 04-03-2011, 02:37 PM
