Thread: Socket/Wrench size for removing knock sensor
Results 1 to 6 of 6
  1. #1 Socket/Wrench size for removing knock sensor
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I'v researched and came across a few different sizes. Just want to make sure before I begin removal. Also is it vital to have it at the correct torque spec? In that case I would think I would need to use a deep well socket to get at it.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Socket/Wrench size for removing knock sensor
    Should be like a 7/8th I think.
    And yes, you must torque it down as that is key for it get the proper readings. The spec is 14 ft lbs.
  3. #3 Re: Socket/Wrench size for removing knock sensor
    Apr 2013
    Milwaukee
    Ok thanks
  4. #4 Re: Socket/Wrench size for removing knock sensor
    Apr 2013
    Milwaukee
    Another quick question. Do I have to drain the cooling system first? And if not, how much coolant usually leaks out after being removed?
  5. #5 Re: Socket/Wrench size for removing knock sensor
    You don't have too, but just the top of the block will drain out, figure maybe upwards of 1 gallon on the high side.
    I'd remove it, catch the fluid and re-use it or add in new stuff. Just take the thermostat out to refill the top half of the motor and then install the thermostat and bleed the cooling system.
  6. #6 Re: Socket/Wrench size for removing knock sensor
    Apr 2013
    Milwaukee
    Awesome thanks
  1. NAPA Evercraft Oxygen Sensor Wrench
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2013, 02:24 PM
  2. What you guys using for an oxygen sensor wrench?
    Last Post: 10-22-2013, 11:10 AM
  3. cam bolt socket size
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2013, 06:15 AM
  4. What size socket for rear axle nut (bearing replacement)
    By poopoopeepee in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 04:01 PM
  5. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
